Old May 5, 2013 | 04:02 PM
  #8221
pig_pit's Avatar
Haha. I have one too. I just dont know where to put it. @Meatbaby.
Old May 5, 2013 | 05:51 PM
  #8222
MEATBABY's Avatar
Originally Posted by xxryu139x
looks like its sticking out its tongue!
That's what everyone says!
Yeah, it took a minute to find the spot. It's not mounted securely enough to be safely used for towing (that's what the oem eye bolt is for I guess). If you take off the grill cover thing just above the actual grill you can look down at the actual metal bumper and there should be a little square hole. That's what I used, just a bolt, washer, and nut. The hole would have to be drilled out though to make it as wide as the hole in the tow strap mounting plate so you could use a wider bolt and make it safe to be used for towing.
Old May 5, 2013 | 07:02 PM
  #8223
krunk13's Avatar
Went to the TruForm meet in Springfield with my buddies...ITR+Speed6+FIT+Cruze Eco
Old May 5, 2013 | 11:10 PM
  #8224
urbanoutfit's Avatar
^^ the t1r tow strap is ugly. Take it off asap
Old May 6, 2013 | 12:20 PM
  #8225
xxryu139xx's Avatar
got this today
took out my old box:
Had to shave off some of the carpeting. it was a tight fit.
Old May 6, 2013 | 12:45 PM
  #8226
Wafulz's Avatar
installed ambient lighting figured how to plug it in thanks to xxryu139x +1 rep
also installed oem floor weather mats they work great today with our light rain
Old May 6, 2013 | 12:49 PM
  #8227
ThEvil0nE's Avatar
holy huge box batman! should have gone with sealed boxes. sealed enclosures have tight, punchy, clean deep bass and you only need a 1-2 liter footprint box.
Old May 6, 2013 | 03:39 PM
  #8228
MEATBABY's Avatar
TRS. Glad you like iT!
Old May 6, 2013 | 04:18 PM
  #8229
xxryu139xx's Avatar
lol thats what it replaced. i like my breath knocked out of me every gutteral beat.
Old May 6, 2013 | 04:31 PM
  #8230
13fit's Avatar
I skipped one and have 3 subs for that purpose
Old May 6, 2013 | 04:34 PM
  #8231
xxryu139xx's Avatar
lol, i still wanna be able to pull out the box. its already 100+ lbs as it is. 3 subs is what like 200+ lbs?
Old May 6, 2013 | 04:37 PM
  #8232
13fit's Avatar
I have 2 boxes, single 10 and dual 12s. Boxes are WEDGED in. every corner I take too fast it groans from flexing the interior panels
Id say the audio setup weights a touch under 200 pounds, as wiring and both amps add some weight, not to mention the boxes are heavily ''bedliner'd'' inside for less bass resonance
Old May 6, 2013 | 04:40 PM
  #8233
ThEvil0nE's Avatar
Trust me... the kidney punches on sealed are ridiculous. sealed is in in all manner better than ported. don't let the small size of a properly powered sealed box fool you. been down that road since the 80s and quit in 05 makes miss my zed amps... oh well...
Old May 6, 2013 | 04:43 PM
  #8234
13fit's Avatar
Yes! my 12s want 1.0 sealed or 1.5 ported, I have them in a 0.75 per chamber box and the 10 wants something like 1.1 sealed and its sitting in a 1.0 ported box lol
Im eventually going to builb a triple sub box that fits the back of the fit so I can regain some cargo space while at same time making the subs sound better by getting them their required space!
still bangs hard as hell, I have the sub channel at -5 gain and bass stuff at zero. Still rattles the fawQ out of my rear view mirror and side mirrors
Old May 6, 2013 | 05:51 PM
  #8235
xxryu139xx's Avatar
i have a prefab sealed box and i wasnt too happy with it. sure it can hit hard but it wasnt moving too much air. i went for a little cruise to Lowe's and goddamn my sub hits hard as hell now. i had the ported box custom made by a builder on caraudio.com. if anyone needs a box pm double07 at caraudio.com.
Old May 7, 2013 | 07:57 PM
  #8236
xxryu139xx's Avatar
my rearview mirrror keeps vibrating so much when i turn up the bass. i took a look at it and it looked like the screw was loose since it was giving way. i unscrewed it and cut up a couple of pieces of 3m outdoor tape and applied it to where the mirror bracket would contact the mirror: the arm frame and the wide flat metal area where the screw presses down against. so far it looks like the window vibration has been minimized!
Old May 7, 2013 | 09:31 PM
  #8237
Bisquick's Avatar
Just placed and order for a B-Spec Fit kit... Now thinking about lightweight tires and wheels.
Old May 7, 2013 | 09:56 PM
  #8238
FittedOnEm's Avatar
Originally Posted by Zalthras
whoo-hoo!! I thought I was the only nut downgrading to 15" I also put 949 6ULs in 15x7.5 +42 with 205/55/15s on the wife's fit.
the fronts poke out a bit, but the rear is perfect. Hope you love em as much as I do.
blast from the past, but i'm considering switching from 17s to 15s and raising the car up.
Old May 7, 2013 | 10:47 PM
  #8239
cjecpa's Avatar
What type of suspension on the car? Any rubbing issues?
Old May 8, 2013 | 03:34 AM
  #8240
ThEvil0nE's Avatar
sweet! welp... rpf1 is light or some Rays eco
