Old Jun 20, 2013 | 10:28 AM
  #8561
ckipps's Avatar
Did a drain and fill of my AT transmission fluid last night, took about 45 mins. I think will do this every other oil change from now on. Also changed my oil mid last week.
Old Jun 20, 2013 | 11:17 AM
  #8562
cjecpa's Avatar
Did STI lip Part Deux first one took on a retread and lost. Plan on doing Plasti-dip front lower grille and back diffuser next. Also contacted Chris at RedShift to get a set of Koni rear sport shocks may go down there to pick up so I can install over the weekend.
Old Jun 20, 2013 | 11:19 AM
  #8563
DeeJayK's Avatar
That seems a bit excessive to me on the AT fluid changing schedule. Do you really feel like it will provide that much benefit? Or do you just need an extra 45 minutes of alone time in the garage every so often?
Old Jun 20, 2013 | 03:34 PM
  #8564
MEATBABY's Avatar
Changing transmission fluid that often is ridiculous. AT should have their fluid changed more often than a MT, but MAYBE once a year if you drive it really really hard or something. Transmission fluid doesn't get nearly as hot as engine oil therefore it lasts waaaaaaaay longer.
Also everyone keeps saying Mugen -lip-. It's not a lip, it's an entire bumper cover (<- that's another common mistake, people always call the plastic part the bumper, but it's a bumper cover. The bumper is the metal bar behind the plastic). The mugen bumper cover just hangs low and has a cool lower design, but a lip would be a separate piece, i.e. the STi lip.
Old Jun 20, 2013 | 04:52 PM
  #8565
connor55's Avatar
Since we're talking about A/Ts...
I thought I'd ask any fellow A/T owners if they ever experience a rubbery kinda crunch from what sounds like the brakes when the transmission is cold and they go from R to D. Happens to me everyday, but only the first time in the day.
Old Jun 20, 2013 | 05:22 PM
  #8566
Black3sr's Avatar
Not from the Fit but my body makes weird sounds when I haul it out of bed in the morning especially after a day of crawling under the Fit dash for another what can I screw up today project.
bill
Old Jun 20, 2013 | 05:55 PM
  #8567
connor55's Avatar
bill
LOL, I'll be doing a lot of that in a couple weeks when I screw around with the climate control.
Old Jun 20, 2013 | 07:09 PM
  #8568
Ef9agent's Avatar
I've noticed this also, I figured it was an auto thing since this is my first automatic car.
Old Jun 20, 2013 | 09:06 PM
  #8569
Speedlimitz's Avatar
I've heard it's the rear brake shoes making the noise
Old Jun 20, 2013 | 09:37 PM
  #8570
connor55's Avatar
I could swear its coming from the front brakes though. Either way, how do you explain why it only happens first thing in the morning? High idle rpm?
Old Jun 20, 2013 | 09:55 PM
  #8571
Maybe we are hearing a different noise. My brake shoes make the noise backing up then starting to drive forward. Like the shoes are flexing backwards in reverse then returning to normal when I start to move forward
Old Jun 20, 2013 | 09:59 PM
  #8572
connor55's Avatar
Hmm mine sounds like that too, but only makes the sound when the transmission is going from R to D. I can also feel the car trying to lurch forward as well.
Old Jun 20, 2013 | 10:47 PM
  #8573
j1nNju1c3's Avatar
I get this too. I thought because it was cold
Old Jun 21, 2013 | 12:30 AM
  #8574
loudbang's Avatar
If it is humid or driven hard and put away the pads "stick" to the rotors. what you are hearing is the pads breaking loose.
Old Jun 21, 2013 | 12:32 AM
  #8575
loudbang's Avatar
That is exactly what is happening. They are not hard mounted so they can move and adjust themselves with the movement.
Old Jun 21, 2013 | 01:21 AM
  #8576
Clownfyre's Avatar
Had a little fit meet today!
need more people !
Old Jun 21, 2013 | 01:36 AM
  #8577
Waiz's Avatar
Avid FitFreak Poster
I have this same problem but only when the engine is cold, I believe it is coming from the axles engaging into drive mode
What I have noticed is that if I make sure to come to a complete stop and then switch to D it doesn't happen. If I roll back slightly and then into D directly I will hear this sound
Old Jun 21, 2013 | 01:15 PM
  #8578
A-Diggy's Avatar
Took the long route into work today and had fun on Skyline and Kings Road.
Old Jun 21, 2013 | 02:58 PM
  #8579
Wanderer.'s Avatar
been thinking of heading up there on a long lunch break lol
Old Jun 21, 2013 | 04:11 PM
  #8580
tfmartin's Avatar
Hit by a charging Ram
I took my car in for repair estimates after being hit by a charging Ram in a local Rec Park.
In a lot of pain but no broken bones!
http://farm6.staticflickr.com/5490/9...4c2336d8_b.jpg
