Old Mar 16, 2014 | 01:16 PM
  #10561
connor55's Avatar
Originally Posted by slimchriz
Ye shall receive!
Hard to get a good pic in the garage
With flash, shutter and bracket is painted red. Can see it some with reflection
Those are sweet, is the light itself red? Or is it just an effect created by the colour of your shroud? Hard to tell from the pic.
Guessing those are morimotos?
Old Mar 16, 2014 | 02:12 PM
  #10562
MEATBABY's Avatar
Originally Posted by mike410b
Except won't all McGard spline lugs have the same distribution of splines? Thus, a universal 'lock.'
Yes I think I see what you mean. But I wouldn't be too worried about the random thief happening to have a McGard key socket. Did I understand your point correctly?
Old Mar 16, 2014 | 02:34 PM
  #10563
slimchriz's Avatar
Thanks Conner.
Yes, Morimoto minis.
I painted the shroud with a anodized red finish over the chrome.
The lights are not on in the pictures its just the flash and reflection, headlights are 55watt 3000k.
Old Mar 16, 2014 | 02:39 PM
  #10564
MEATBABY's Avatar
Gave it a much needed bath and spring cleaning with my FlexDA.
Lookin great as always. Since I know you're into "spirited driving," what psi do you run in the tires? Same front and rear or different?
Old Mar 16, 2014 | 03:12 PM
  #10565
connor55's Avatar
Thanks Conner.
Cool nice work.
Is 3000k even legal for headlights? I thought they had to be considered "white" and that 3000k is considered amber according to dot regulations? Seems a little risky IMO.
Old Mar 16, 2014 | 05:38 PM
  #10566
Wanderer.'s Avatar
IDK about McGard, but Gorilla has specific keys for specific nuts. They give you a sticker with the key code for the nuts you have... i'm not sure if the key is the same across all spline nuts or if there's a few different keys though?
Maybe if someone knows for sure you can lmk?
Old Mar 16, 2014 | 05:49 PM
  #10567
Goobers's Avatar
The thing is, the Gorillas are listed as lock nuts. The McGard the poster has are not classified as lock nuts. They appear to have evenly spaced splines. The spline w/lock sets specifically say it has 4 lock nuts.
Old Mar 16, 2014 | 06:04 PM
  #10568
MEATBABY's Avatar
Yeah, the McGard are all the same as far as the spline drive goes. They key is pretty cheap, but still, unless someone staked out my car, figured out what lug nuts they are, then ordered the key, I'm fine
Old Mar 16, 2014 | 06:21 PM
  #10569
connor55's Avatar
Unless it was one of us that wanted your wheels
Old Mar 16, 2014 | 06:24 PM
  #10570
MEATBABY's Avatar
I've said too much already
Old Mar 16, 2014 | 06:34 PM
  #10571
555sexydrive's Avatar
I run 31.5~32f and 32~32.5r daily. On circuit my track tires I start off with 23f and 26r and by the time a 30min session is complete the pressures are about what I run daily depending on the conditions.
Old Mar 16, 2014 | 06:38 PM
  #10572
MEATBABY's Avatar
Cool. Why more in the back? I would think you would want more in the front because of the extra weight, no?
Old Mar 16, 2014 | 06:54 PM
  #10573
Help with rotation.
Old Mar 16, 2014 | 09:24 PM
  #10574
connor55's Avatar
Help with rotation.
can you elaborate more on that for noobs like me?
do you mean rolling resistance or for even tire wear from front to rear?
Old Mar 16, 2014 | 11:23 PM
  #10575
To inhibit a bit of oversteer and lessen understeer. My car with differential and the suspension is pretty neutral, but still has some understeer at the ultimate limit; with harder rear pressures you can dial in some oversteer. Kind of the way people over-inflate their tires for FE. I won't ever run with pressures so high, as I don't care about FE, I care about handling and performance.
Though this all comes into one's preference in handling feel, what I like, might not be what another likes when it comes to setup. And now that I think about it, I usually run 2psi more in the rear and not just 1. Factory specs call for 1~1.5psi more in the front if I remember correctly.
Old Mar 16, 2014 | 11:26 PM
  #10576
dvleucsd's Avatar
Installed the Bilsteins!
Old Mar 16, 2014 | 11:31 PM
  #10577
slimchriz's Avatar
Cool nice work.
No, blue or red are illegal and in NH they dont even stop people with the PNP blue HIDs so Yellow is a non issue.
Old Mar 17, 2014 | 01:41 AM
  #10578
connor55's Avatar
Interesting, well I guess laws vary from state to state.
Just curious why you chose 3000k for headlights though. They don't output as much visible light as 4300 or 5000k
Okay I see how that works now. I have to remember that not all of us want just want efficiency lol.
Maybe I'll toy around with my front and rear pressures to see what effect it'll have. I usually have about 36 front 34-35 in the rear, but then again mine is a daily driver and won't be seeing the track anytime soon
Old Mar 17, 2014 | 02:29 AM
  #10579
YeahItFits's Avatar
Senior Member
Finished off my retrofit.
Infiniti M45 Projectors &Shrouds.
TSX-R Lens Swap.
First Retro;
Everything that could've good wrong, went wrong.
Old Mar 17, 2014 | 11:16 AM
  #10580
SiRca90's Avatar
Just bought some rpf1s in 16x7 +43
