Old May 27, 2015 | 08:32 PM
  #13121
xxryu139xx's Avatar
traded in my Interstate Megatron D51R back to Firestone for a warranty replacement. First one died within 5 months...
Old May 28, 2015 | 12:55 AM
  #13122
spryter's Avatar
Originally Posted by wzlfit
Washed, waxed and new wiper blades. Ever notice car products tend to smell like stripper perfume?
I have AutoGlym interior shampoo. Smells like Old Spice.
Old May 28, 2015 | 01:02 AM
  #13123
phenoyz's Avatar
Originally Posted by richardhylands
where did you get the center cap for the enkei?
i am looking for a cap like that for my 15x7
thanks
Old May 28, 2015 | 09:37 AM
  #13124
PaleMelanesian's Avatar
I bought a 51R battery. My 151R only lasted 2 years. It'll be a tight fit between the airbox and headlight, but I bought a set of top-to-side and side-to-top terminal adapters to move the positive terminal fuse block out of the way. Will do the install tonight.
Like this: https://www.fitfreak.net/forums/2nd-...o-problem.html
Old May 28, 2015 | 09:43 AM
  #13125
MEATBABY's Avatar
thanks
Google is your friend - Diy-Rpf1 Center Caps using oem honda caps - S2KI Honda S2000 Forums
I'm sure there are other methods and DIYs out there if this doesn't work for you. Just search the interwebs.
Old May 28, 2015 | 12:38 PM
  #13126
richardhylands's Avatar
thanks
Buy the caps off aliexpress.com for a Honda Element
buy the decals off ebay.
black spray can to cover the caps (5 coats)
Apply decal
clear coat 3 to 5 coats
Old May 28, 2015 | 02:17 PM
  #13127
connor55's Avatar
Apply decal
Can you tell me how you accessed the area behind the fogilight without needing to remove the lip or bumper?
Old May 28, 2015 | 02:42 PM
  #13128
Yes, so basically I jacked the car up as high as possible and took off all the underneath plastic. Then I could get behind the fogilight. My wiring was installed backwards. The oem harness clip is under the passenger side fender and my clip for the fogs was at the drivers side. So in that pic I'm just re doing it.
Old May 28, 2015 | 03:27 PM
  #13129
wzlfit's Avatar
Installed CURT T-harness. Worth the extra cash to not have to cut oem wiring so i could put it back easily. It just plugs in between the oem harness and the tail light.
Old May 28, 2015 | 04:27 PM
  #13130
Black3sr's Avatar
[IMG][/IMG]
Try a high end one.
Old May 28, 2015 | 05:40 PM
  #13131
connor55's Avatar
Including the fenderliner? Cause that sort of wedges behind the bumper. Man that sounds like a pain
Old May 28, 2015 | 05:50 PM
  #13132
xxryu139xx's Avatar
Installed my new Interstate Battery D51r today. Couldnt do it yesterday due to the torrential downpours. Started unplugging my Scangauge everytime i leave the car. Hopefully that minimizes the battery drain. Hope this one is good.
Old May 28, 2015 | 08:17 PM
  #13133
MEATBABY's Avatar
What wiper blades did you go with?
Old May 28, 2015 | 08:57 PM
  #13134
xxryu139xx's Avatar
bought some Koni Orange Rears from Tirerack. gonna try to DIY =p
Old May 28, 2015 | 11:18 PM
  #13135
g95pteg's Avatar
Why just the rears?
Old May 28, 2015 | 11:25 PM
  #13136
xxryu139xx's Avatar
Originally Posted by g95pteg
Why just the rears?
eh im being cheap
Old May 28, 2015 | 11:32 PM
  #13137
MEATBABY's Avatar
Nothing could be easier than the rear shocks on the Fit. Air tools will make that bottom bolt come out and go back in a whole hell of a lot faster.
Old May 28, 2015 | 11:47 PM
  #13138
xxryu139xx's Avatar
damn wish i have air tools.... i got my ghetto breaker bar though
Old May 28, 2015 | 11:54 PM
  #13139
connor55's Avatar
That and some kroil and youre good to go
Old May 29, 2015 | 12:19 AM
  #13140
wzlfit's Avatar
Bosch icon. They claimed to be aerodynamic long lasting even with ice. My old all season blades would move around and lift on the highway. No lift and clean windows. Wanted to try the rainex blades but they didn't have one small or big enough. The only back replacement was some cheap blade that doesn't work well.
