Old Jun 5, 2015 | 08:48 PM
  #13181
bensenvill's Avatar
got caught up with parts I had laying around for a while. got the center armrest in and was finishing the ambient light kit.. Also swapped in a leather steering wheel and realized I lost horn functionality so I'll need to pull it back off and swap back to the original wiring, no biggie. Nice to add a few little touches to the interior.
Old Jun 5, 2015 | 09:09 PM
  #13182
kudakev615's Avatar
Originally Posted by connor55
So clean. I think i like the depos better than those light bar tails.
thanks bro. ive def seen your fit on here and on IG and it has me thinkn should i go air ride before the major power upgrades i agree, the depo tails suit the car better and i'll swap back to them p soon. though i do prefer the look of 17's on the car, i prefer the ride on 16's
Old Jun 6, 2015 | 03:28 AM
  #13183
eternal_fantasy's Avatar
Back seat delete - Took 2 minutes to unbolt, 20 minutes to haul the seats back up my apartment...
Weighed the back seats and spare tire, came out to around 43Kg(~95lbs) total... It caused my rear wheel wells to lift by 8mm, and around 2mm in the front, which I adjusted back on my coilovers.
Weight breakdown:
Rear Seat Large - 17.7Kg (~39.0lbs)
Rear Seat Small - 13.5Kg (~29.8lbs)
Spare Tire - 10.5Kg (~23.1lbs)
Other bits and bolts - ~1Kg
Noise increase was less then expected, more of a minor echo effect then anything else.
Last edited by eternal_fantasy; Jun 6, 2015 at 03:40 AM. Reason: Added weight breakdown
Old Jun 6, 2015 | 10:36 AM
  #13184
MEATBABY's Avatar
Originally Posted by eternal_fantasy
Weight breakdown:
Cool thanks for actually weighing those parts out. Used to have the back seats out and liked it. Put them back in at one point so I could haul people around. Not doing that anymore and have been meaning to get the seats out again. This will push me to actually do it now.
Old Jun 6, 2015 | 11:25 AM
  #13185
connor55's Avatar
Can you feel much of a difference in the driving characteristics?
Old Jun 6, 2015 | 11:54 AM
  #13186
wzlfit's Avatar
Weight breakdown:
Noise increase was less then expected, more of a minor echo effect then anything else.[/QUOTE]
Thanks, I was wondering bout that info.
Old Jun 6, 2015 | 12:05 PM
  #13187
No problem! I'm also in the position that very rarely does the back seats get used, and seems simple enough to remove.
Purely subjective, The car felt more sprightly. 4% of total car weight removed causes a noticeable improvement in acceleration and breaking. The rear seems slightly looser around corners, reducing the inherent understeer. It might increase perceived rear suspension damping however, which I reduced by one click on my rear damper stiffness setting.
Or it could, of course, all be in my head...
Old Jun 6, 2015 | 01:09 PM
  #13188
Mr.Hollow's Avatar
It very well could be, but if makes you feel like your having more fun while driving then there isn't really a downside.
Old Jun 6, 2015 | 02:23 PM
  #13189
Waiz's Avatar
Avid FitFreak Poster
Good idea to remove the rear seats if you're not using them
Thanks for weighing them, I have been curious
Old Jun 6, 2015 | 04:57 PM
  #13190
phenoyz's Avatar
LOVE those blacked-out tail-lights and rear bumper, where did you get those? Thanks
Old Jun 6, 2015 | 05:28 PM
  #13191
xxryu139xx's Avatar
Weather cleared up and I was able to get to install my Koni rears. Followed the instructions from the Honda Manual. Worst part was untorquing the bolts.
Here they are installed:
This is the cylinder that needs to be grinded off with a dremel. You can see the notch where it holds the bolt in place. Once its ground off, use a 5 mm hex to hold the screw and place and turn the cylinder with a wrench and it will screw right off.
Dumb ass me planned to use the new spacer and nut from Koni but I dropped them behind the damn panels. I'll go fish for them some other day. I don't hear them rattling anywhere.
Took a spin and the back is less bouncier than before. Hopefully my fam comes through and buys me the front Konis for my birthday!
Attached Thumbnails What did you do to your GE fit today?-20150606_153343_zpsvqr2ifqu.jpg   What did you do to your GE fit today?-11403434_10153217087130862_4863770459775064987_n-201_zpssysfpcjl.jpg   What did you do to your GE fit today?-20150606_140118_zps26ajoj4u.jpg   What did you do to your GE fit today?-20150606_134105_zps6yc04akx.jpg
Old Jun 6, 2015 | 10:31 PM
  #13192
QFT. I hate anecdotal data so am critical of my own experience unless there are actual scientific data to back it up. I could swear the 4 point front underframe chassis brace was actually making my car stiffer, but am unconvinced by what could very well be my own willingness to believe...
The tail lights are from Axis styling Japan. http://axis-jp.com/ge_te-ru.html I believe there were a group buy on fitfreak some time ago for these.
The rear bumper is a replica of the Mugen Fit RS bumper. Costs 1/3 of buying the actual JDM RS rear bumper and the Mugen bumper addon... which being a bumper are subject to inevitable "bumping" by the swarm of scooters lane splitting in Taipei.
Old Jun 6, 2015 | 10:48 PM
  #13193
connor55's Avatar
Is the fourth brake led also a replica? Where did you get that and how much is it?
Old Jun 6, 2015 | 11:23 PM
  #13194
FamilyWagon's Avatar
Took off muffler and ran a straight pipe axle back. Love it!
Decided to go this route since there's not really any options for a Mugen rear end.
Old Jun 6, 2015 | 11:25 PM
  #13195
ampete04's Avatar
Well if you calculate weight / hp. Our cars weigh 2,500 lbs / 117hp = 21 lbs per 1hp. So, every 21 lbs weight reduction should feel like 1 additional hp. Right?
Old Jun 7, 2015 | 12:53 AM
  #13196
The the bumper fog light came with the bumper... although I think you can find them on some auction sites for around $30 USD. ÅS¤Ñ©ç½æ-¥xÆW NO.1 ©ç½æºô¯¸
(Taiwanese equivalent of eBay) As a comparison the real Mugen fog light costs over $400 USD...
I have mine wired to perform as 4th break light, and was surprisingly durable. 3 years of use and no moisture damage or dead LED.
Well 4hp is sometimes the difference between a good dyno run and a bad one... although of course any weight reduction will help.
Old Jun 7, 2015 | 01:01 AM
  #13197
swflej1's Avatar
Old Jun 7, 2015 | 07:34 PM
  #13198
xxryu139xx's Avatar
figured i'd give my car a wash. lotsa bug splattage from my trip to Niagara Falls two weeks ago. got a small dent on my hood too and more scratches from last year. meh. my foam sprayer works now, wish it really foamed more. bug and tar got most of the bug stuff off. need to claybar one of these days. figured while i'm at it might as well wax. nice and shiny again.
Old Jun 7, 2015 | 09:49 PM
  #13199
connor55's Avatar
Is it actually any good other than durability? 30 bucks seems like a steal considering the mugen ones are like 500.
Also, does it really flash and have 43 leds? Doesnt look like 43. I wonder if the cops here would have a problem with the flash.
Old Jun 8, 2015 | 12:34 AM
  #13200
It does what it's advertised to do, so I guess it's good in that way...
It has 2 lighting modes. With normal wiring, it lights up to levels matching the tail light when headlights are on, and flashes(VERY Brightly) 3 times then stays very bright when you step on the brake, until the brakes are released. However I'd hate to be behind one when it contentiously flashes and blinds you.
Here is a clip showing a similar light on a Civic https://youtu.be/vVjEl8-sSZc?t=15s
I have it wired so that it only lights without flashing and at low levels when break is applied.
I've made a bump steer kit out of 7075 T6 Aluminum since there are no steering tie rod bump steer kit for the Honda Fit because of the knuckle design. There is noticeable bump steer after installing the extended ball joint(Roll Center Adjuster). It is essentially power steering rack shims that raises the entire rack by 8mm.
It awaits sand blasting and hard coat anodizing. Hopefully there is enough room above the steering rack...
