Adding keyless to US Base 2009 Fit
Old Jan 28, 2020 | 11:50 AM
  #61
Tomnkc's Avatar
I realize this is an old thread but will this same process work on a the 2010 base model. Thanks
Old Jan 28, 2020 | 03:18 PM
  #62
julianachos's Avatar
Yes it will
Old Jan 28, 2020 | 05:02 PM
  #63
Tomnkc's Avatar
Thank you for your reply
Old Feb 1, 2020 | 06:56 AM
  #64
Tomnkc's Avatar
Received the key ($43) yesterday and was able to easily program it to operate the door locks and panic on the 2010 Fit. It took me a few tries to realize you need to take the key out of the ignition for the newly programmed key/remote to work. Just follow the above directions and then remove the original key from the ignition to test the new remote. Thanks to all for the help on this. In my case the the drivers side key cyl. is jacked and this was the cheaper and ,in the long run, the better alternative to replacing it.
Old Feb 1, 2020 | 06:59 AM
  #65
Tomnkc's Avatar
I am curious if anyone has tried an aftermarket /non OEM blank/remote to do this? I bought the OEM online from a dealer but was curious about the others.
jinuevo
Sep 12, 2018 06:14 PM
greywolf1940
Aug 9, 2016 02:15 PM
Brain Champagne
Jul 3, 2011 08:15 PM
DrKelso
Aug 31, 2009 12:47 AM
Billburg
Aug 1, 2009 09:38 PM
