Key Fob Distance?
Old Jun 26, 2009 | 12:46 AM
NavyAC's Avatar
Unhappy Key Fob Distance?
I just wanted to know if I am the only one who has to be up close to their car just to get the remote to work. I had a remote start installed from the stealership but it's worthless since I have to be so close just to get a signal. Does anybody know where the antenna for the receiver is? Is it upgradable? Thanks in advance.
Old Jun 26, 2009 | 10:08 AM
bigangrytexan's Avatar
From my experience, you have to be fairly close to the car. For me, it won't work unless I'm within 30-40 feet, which is surprisingly close. My other car, a 04 Chevy Silverado has a remote range of over 50+ yards when it has a new battery!!!
Old Jun 26, 2009 | 10:19 AM
McNabb's Avatar
The range on the Fit is quite small, but I am used to our Subaru, which is the king of remote distances for some reason. That was confirmed last month when Car and Driver did a test and found the Subaru and Dodge to have about 4 times the range of most other cars.
Old Jun 26, 2009 | 10:33 AM
NavyAC's Avatar
So nobody has any idea how to extend the range?
Old Jun 26, 2009 | 12:13 PM
stevet47's Avatar
I did this to my nissan. I am sure the same could be done for the fit. It added 30' of range.
Add 30' of range to you KeyFob. - Nissan Frontier / Navara Forum
If you have to be logged in to see it, let me know and I will just post the pics.
Old Jun 26, 2009 | 12:59 PM
Uncle Gary's Avatar
The Fit has better range than my '02 Neon did. That car, you had to be within 10 feet for it to work! Replacing the battery didn't help a bit.
Old Jun 26, 2009 | 01:49 PM
Bariki's Avatar
Get better range by putting the key fob against your head when you lock/unlock.
Old Jun 26, 2009 | 03:34 PM
benmunger's Avatar
He's not joking. ^
your skull magnifies the signal. hold it to your head.
Old Jun 26, 2009 | 03:40 PM
benmunger's Avatar
you can move the receiver higher. Its under the drivers dash and its a little black box about 1.5" X 1" X 0.75" (just estimates). It has 4 wires going in to it, on a five pin harness. (black, brown/orange, yellow, white/red)
Splice/extend the wires and run it up the pillar in to the roof.
Please measure your distance and see how much farther range you get. If it works out well, maybe Ill do it too.
Old Jun 26, 2009 | 04:04 PM
stevet47's Avatar
Sounds like a good idea. Someone should find the right connector and just make an extension and sell them.
Old Jun 26, 2009 | 09:28 PM
reako's Avatar
He's not joking. ^
Yep, pretty cool. Just place it under your chin. Here's an illustrated example of the results you may achieve:
Intel radio expert Robert Paxman explains:
“It comes down to antenna efficiency. If a transmitter operating at ‘x’ frequency range has an antenna that might be lacking in efficiency and you couple it to something that creates a situation for better efficiency, getting that added range is plausible. Because the body has some conductivity, placing it close to some body part would create a coupling effect. Think back to the days of TVs having “rabbit ears” for antennas. Sometimes the best reception and clearest picture was had when you were touching it. The same principle applies here.”
Reference: Car Alarm Remote Touched To Head - Everyday Tech Myths - Tom's Guide
Old Jun 26, 2009 | 10:10 PM
Benggolf's Avatar
I'll add to that....open your mouth wide and aim towards your car.
Now you are like a parabolic antennae amplifying and directing the signals to your car.
Old Jun 27, 2009 | 05:27 PM
txmatt's Avatar
Mine is fine... with no obstructions I can lock/unlock from 30-50 yards away with the head/chin trick mentioned above.
derykisonder
Jun 11, 2023 04:08 PM
bjosuesr
Feb 28, 2023 01:34 PM
obaa996
Aug 10, 2017 01:51 PM
randomracer
Jun 18, 2008 12:01 AM
KnifeEdge_2K1
Apr 12, 2008 01:45 AM
