Airbox labrynth ? WTF
Old Sep 24, 2009 | 04:35 PM
slimchriz's Avatar
Anyone know what the deal is with this airbox?
I just pulled my filter to have a look and its ridiculous...
Also are there any mods that can be done to the airbox to improve intake sound?
I searched but either terms are too common or I came up empty.... search sucks....
Old Sep 24, 2009 | 04:46 PM
Committobefit08's Avatar
some members just removed the air reservoir lid. Its right above the intake inlet. I tried this but it was a little too loud for me.
What I did is drilled out the side of the reservoir lid instead of taking the whole thing off. I cut out the side just above the intake inlet. Now essentually it pulls air from the under hood scoop through the intake inlet and the reservoir box opening. Probably helps the car breath a little better. This gave the car a deeper growl to it but not too loud. Don't think it does anything performance wise but with my K&N drop in filter it sounds a lot better imo.
FYI I ordered a new lid in case I didn't like it...just to be safe. New lid cost $7 at Bernardihonda.com.
Old Sep 24, 2009 | 04:54 PM
slimchriz's Avatar
Ok yah I just pulled that off to look in there and was thinking the same.
Looks like a good spot too the air vent is right there...
Thanks...
Old Sep 24, 2009 | 05:44 PM
fmcfad01's Avatar
Could you post the part number of what you removed/drilled or take a picture of your mod? I'm not visualizing it.
Old Sep 24, 2009 | 08:00 PM
Sure its part #3 in the picture. I circled the side I cut out.
Here is where I got it from...
http://www.bernardiparts.com/searchoptions.aspx
sorry it was $7.71
Part # 17202-RB0-000
Old Sep 24, 2009 | 09:26 PM
mike2100's Avatar
I drive with mine off. Sounds and runs fine.
Old Sep 24, 2009 | 09:39 PM
fmcfad01's Avatar
Can someone explain the logic behind this multi chamber intake path? I mean, it looks like nothing I've ever seen before and makes no sense. It's like the least direct air path I've ever seen. Why don't they just have an orifice go through the airbox/filter then into the intake manifold? It seems weird there are all these extra caverns.
Old Sep 24, 2009 | 10:44 PM
awptickes's Avatar
Some people would complain about the noise of the engine if they made it a direct path intake. Many people want a car that's dead silent unless something is wrong with it.
Old Sep 24, 2009 | 11:24 PM
mike2100's Avatar
Yep, always a balance between power and sound level. Maybe the door on the chamber was intentional, so those who don't care about sound level can take it off to get a bit more power. Who knows
Old Sep 25, 2009 | 12:25 AM
Red 05's Avatar
That's not bypassing the filter is it? It's late and I really shouldn't be up....>.<
Old Sep 25, 2009 | 09:18 AM
Uncle Gary's Avatar
IIRC, that plenum box is upstream from the filter.
I don't know why the convoluted multi chamber design unless it's to provide sufficient airflow silencing in the minimal space available.
Old Sep 25, 2009 | 09:32 AM
awptickes's Avatar
^^ there you go.
My civic had something similar, it was a big box that didn't do anything but try to act as a pressure buffer, and when I took off that big plastic box, it was loud. I put the plastic box back on, and it was quiet again.
Keep in mind that I didn't remove anything other than the box at the very bottom of this picture:
Old Sep 25, 2009 | 10:15 AM
fmcfad01's Avatar
Well I guess the thing does it's job, because you can hardly tell the thing is running when idling. I may try taking that hatch off next week. I've got a nice weekend planned in the M Coupe with some end of season autocrosses complete with lots of engine and exhaust noise.
Old Sep 25, 2009 | 10:16 AM
awptickes's Avatar
Where are you racing?
Old Sep 25, 2009 | 10:50 AM
slimchriz's Avatar
I drilled 3 3/4 inch holes in the side would have gone a little bigger but all my paddle bits are at work.
Still silent at idle but has a nicer tone at wot.... not loud enough for me though Im going to try without it today.
Old Sep 25, 2009 | 10:58 AM
mikejet's Avatar
You can cut the baffles out or replaces it with an aftermarket intake. I don't mind it too much though.
Old Sep 25, 2009 | 11:59 AM
Red 05's Avatar
I'll try without it today on the way to my work.
Old Sep 25, 2009 | 07:57 PM
BobsUrUncle's Avatar
I took off the cover last night, and drove to and from work today, mixed driving. WOT was louder than usual. I couldn't really feel any openings that passed air, figured it was a resonance box.
Old Sep 25, 2009 | 08:44 PM
slimchriz's Avatar
It does draw air you can feel suction from the holes I drilled...
and if you shine i light from under you can see it faintly very odd path though..
Anyways I drove around all day today with the cover off... sound was a little louder but also a harsher sound think ill drill a 4th hole and replace cover...
Myxalplyx
Apr 11, 2015 09:56 PM
yovtecjustkickedin
13
Apr 5, 2015 02:08 AM
Cordizzle4life
Jan 5, 2012 11:50 AM
ThEvil0nE
Oct 15, 2010 12:22 PM
Rod2Rice
Jul 24, 2008 11:06 AM
