Basic MM question (sorry).
Old Sep 23, 2011 | 09:49 AM
blazej's Avatar
I have 27K miles on my car and have gotten the oil changed 2 times so far (both times when the MM was at 20%). The MM is currently at 30% and I'm thinking of changing the oil soon (when it's at 20%).
I have never had the MM give me another code at all. My question is does the oil indicator need to reach 0% before other MM indicators are displayed?
Should I wait until the MM shows 0% and then reset my indicator or is this just because at 27K miles, the MM codes have had no need to display?
Thanks.
Old Sep 23, 2011 | 09:53 AM
Wes2theG's Avatar
I'm not sure why you would WANT to run it to 0%? That just sounds like it wouldn't be good.
Old Sep 23, 2011 | 09:57 AM
blazej's Avatar
I would change the oil at 20%, but not reset the indicator. I'm just worried that I haven't had any codes or anything yet.
Old Sep 23, 2011 | 10:14 AM
malraux's Avatar
Codes show at 15%.
Old Sep 23, 2011 | 10:26 AM
spreadhead's Avatar
You can hold the button down for about 10 seconds, the codes will display. Do not press the button again, the MM wil not reset and mileage display will return to normal.
Old Sep 23, 2011 | 10:30 AM
Hootie's Avatar
^^ Ditto. You just haven't driven far enough past 20% for the codes to pop up. Once the car hits 15%, the MM percentage will pop up as well as a code with the letter "A" or "B" as well as a number or combination of the numbers 1 through 5.
If you are not sure of what the codes would mean please refer to the image below. Disregard the fact that this is from the 2008 Fit manual, the maintanence minder codes show exactly the same on the majority of Hondas except for AWD & 4WD models (which have a 6th number for their transfer cases and rear differential fluid).
If you cannot read the image either save it on your hard drive, click it and zoom in or right click the image, open in new tab, then his "Ctrl" and scroll up on your mouse to zoom in.
Old Sep 23, 2011 | 10:53 AM
blazej's Avatar
Awesome. I'll do 2 things:
1) Wait to get to 15%
2) Press the button down for 10 seconds to see what codes pop up.
I didn't know either of those things. Thanks a lot!
Old Sep 23, 2011 | 10:58 AM
Hootie's Avatar
No need to press any buttons for codes. The very moment the oil life hits 15%, it will instantly display "15%" as well as the letter and number(s) code system. This will constantly pop up every time you start up the car and will disappear once you tap the trip/select button but still store the code and percentage.
The only time the trip/select button really has to be held down is during MM reset.
Old Sep 23, 2011 | 12:16 PM
Krimson_Cardnal's Avatar
I like the MM. If only it could mow a lawn.....
Old Sep 23, 2011 | 12:54 PM
i start thinking about doing an oil change at 15% when the wrench icon lights up. actually my GE is at that point right now so i will be doing the change on Sat.
ive had the car go into -400miles or something once. nothing happened though.... no voice saying i must change now or else... im using synthetic so -400 is nothing. the wrench icon is based on dino oil.
Old Sep 23, 2011 | 05:47 PM
I'm thinking that 'voice' opens up a rather interesting story line... fit noir.
The Fitness
Mar 8, 2014 07:28 PM
MTLian
Jun 4, 2013 04:05 AM
SilverbulletCSVT
Apr 26, 2013 12:08 AM
Eugene.Atget
Feb 23, 2013 02:12 PM
blazej
Sep 23, 2011 09:55 AM
