MM codes
Old Apr 24, 2013 | 10:14 PM
SilverbulletCSVT's Avatar
MM codes
Is there a way to see the upcoming MM codes before your MM reaches 15%? Currently at 20% and want to change the oil before a long trip this weekend but don't want to lose the code(s). I suppose if no other way I could change the oil without resetting MM and then at 15% observe the codes and reset it.
_
Old Apr 24, 2013 | 10:52 PM
jmsplitfyre's Avatar
Go to the percentage screen, press and hold the knob for 8-10 seconds until it blinks. It will then show you the next service needed.
Then to reset it, while the minder is blinking press and hold the knob again until it turns to 100%.
Old Apr 25, 2013 | 06:58 AM
Thanks. I saw that in the manual but wasn't sure if the codes appeared before 15% or not. I didn't try it because it wasn't clear if the blinking would eventually stop and revert to normal screen or if you had to reset MM to stop the blinking.
_
Old Apr 26, 2013 | 12:08 AM
Press and release will get you out of the blinking screen.
The Fitness
Mar 8, 2014 07:28 PM
MTLian
Jun 4, 2013 04:05 AM
Eugene.Atget
Feb 23, 2013 02:12 PM
blazej
Sep 23, 2011 05:47 PM
SmartSizer
Dec 11, 2009 08:21 PM
