The END of FitDeez!!!?
Old Jan 27, 2012 | 03:22 PM
  #101
FitDEEZ's Avatar
And of course this wouldn't happen if it had stock suspension because coilovers are stiffer. My car never bottomed out the suspension or anything like that it's from the impact of hitting potholes and bumps in these horrible roads and its a shame
Old Jan 27, 2012 | 03:31 PM
  #102
FitStir's Avatar
Thanks for the update Deez. Hope all works out soon enough for you. These roads here are horrendous even on stock suspension/wheels.
Old Jan 27, 2012 | 03:35 PM
  #103
doctordoom's Avatar
Supervillain
Dang, that is some gnarly damage.
Are you planning to do anything else during this process, besides repairing and reinforcing those areas? I don't know, like weld the strut towers to accept pillowball upper mounts or camber plates for example? Since I know you like to get low.
Looking forward to your repaired fit, good luck!
Old Jan 27, 2012 | 04:12 PM
  #104
Goobers's Avatar
Originally Posted by FitDEEZ
This damage was not caused by having coilovers or having wide wheels it's came from hitting potholes and the damage became worse over time, probably starting by breaking a spot weld if I hit a bad pothole and So on until it got how it is now .
What is the meaning in the second quote?
Because my interpretation of that bolded part, means you ARE blaming the coilovers. Which you were defending in the first quote.
Maybe you did bottom out... and simply thought it wasn't severe (kinda like the opposite, where people think things are worse than they are).
In any case, it could simply boil down to, not that the coil overs being too stiff for handling, but they are too stiff for (your) road conditions.
Incidentally, I have bottomed out my car on stock suspension (probably more than one occasion too). I have been a touch more careful with the Swifts.
Old Jan 27, 2012 | 04:48 PM
  #105
GAFIT's Avatar
Thanks for the update and good luck with the repair. I've driven around NY/NJ and it's like driving in a war zone. As I mentioned earlier, my friend was chewing through factory DSM wheels on his Eclipse Turbo because with heavy traffic sometimes the potholes are unavoidable.
Old Jan 27, 2012 | 06:04 PM
  #106
Simply Fit's Avatar
Man honda should have a recall on that
Old Jan 27, 2012 | 06:39 PM
  #107
eurobeaner's Avatar
Yea.... Because everyone is at risk.
Only one to ever happen, on stiff suspension, low offset wheels, and horrible roads. Man, every fit is at risk!?!?!! Zomfg
Anyway. Mr fitdeez, after welding, I would for sure add a strut tower/firewall brace to that. Then dump again and be the hottest fit on this forum
Old Mar 9, 2012 | 06:02 PM
  #108
komafit's Avatar
Any updates?
Old Mar 9, 2012 | 06:45 PM
  #109
wontfit's Avatar
Nah man, weld. Sell. Try again.
Old Mar 9, 2012 | 11:06 PM
  #110
FitDEEZ's Avatar
Yeah, wow can't believe I forgot to update.. I took the suspension out pulled the shock tower back down to where it belonged , lined it up and welded it all around instead of little tack welds and now the car is back together actually better then before since its stronger then the original welds
Here's a pic of it lined back up
Old Mar 9, 2012 | 11:10 PM
  #111
Btrthnezr3's Avatar
Have any more pics? Did you do the other side as well?
Old Mar 10, 2012 | 02:19 PM
  #112
FITMugen's Avatar
Heavy spots or reenforces like these would be appropriated.
Old Mar 10, 2012 | 08:13 PM
  #113
Perrenoud Fit's Avatar
No way that's not right 2 spotwelds there should be 6 or more there. I'm going out and check to see how many MzFiT has there. Sorry brother that's another 1 of the nicest GE's here!
GLOR
Ya Deez I checked my GD and I counted 6+ spot welds in the same location.
Honda has sum esplain'n to do, keep us posted.
Mike
Old Mar 10, 2012 | 09:50 PM
  #114
Goobers's Avatar
GLOR
Mike
Are you counting ALL the spot welds, or just within the few visible inches shown on FD's pics? Cause if you want to count all of them, there are plenty more, at least 9 (7 plus the 2 shown) dealing with the strut tower housing.
I'm pretty sure all GEs have the same number of spot welds, since I'm fairly certain this part was done by a programmed robotic arm.
Old Mar 11, 2012 | 01:24 PM
  #115
Texas Coyote's Avatar
If there is no more then 2 spot welds on that part of the strut towers, Honda is not on top of their quality control.... I like looking at dropped (slammed) cars with crazy offset for the hella flush thing but really guys there will be a time when the lack of suspension travel, stiff springs and damping is going to create problems.... I know this to be a fact because I have experienced it myself when I was half the age I am now..
bennett707
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Nov 13, 2014 11:33 PM
ewong12
14
Jan 11, 2012 01:38 AM
GD3_Wagoon
Jan 31, 2009 05:00 PM
Mr. Moose
Sep 20, 2008 02:29 PM
Sugarphreak
May 20, 2008 05:06 PM
