Camber bolts
Old Jul 2, 2012 | 11:02 PM
mkane's Avatar
Camber bolts
Installation's straight forward. Maxed out the adjustment. I'll keep an eye on tire wear. One auto x with the stock setting completely trashed a 1" strip on the tires. This won't happen again. Cars a bit sensitive just off center but once it takes a set theres a marked difference in feel. More rubber on the ground I suppose. New tires before the next auto x on the 14th. Highly recomended if you like spirited driving under the right conditions.
Old Jul 3, 2012 | 07:56 PM
lowkeymods's Avatar
or you just like to turn better in the city
Old Jul 3, 2012 | 08:53 PM
solbrothers's Avatar
You should get an alignment. If the GE is anything like the GD, adjusting the camber adjusts the toe as well. You'll eat through your tires in a couple hundred miles.
Old Jul 3, 2012 | 08:54 PM
Wait, you adjusted the camber which way? more negative camber or more positive?
Old Jul 3, 2012 | 09:00 PM
lowkeymods's Avatar
Did that today...toe was waaaaaaaaaay off.
Old Jul 3, 2012 | 09:09 PM
mkane's Avatar
Positive. Drove it 500 miles already and tire wear looks fine. I used a large square placed up against the base of the tire and measured from that to the top of the rim. Seems fairly equal, within 1/32" side to side.Yes, it stiill needs to be checked for toe but tracks perfect going down the road.
Old Jul 3, 2012 | 09:40 PM
why would you make your camber more positive?
Old Jul 3, 2012 | 11:09 PM
mkane's Avatar
Your saying I got it backwards. Wheels in at the top. Neg. not positive?
Old Jul 3, 2012 | 11:16 PM
oh okay. so you wanted more negative camber?
Camber angle - Wikipedia, the free encyclopedia
Old Jul 3, 2012 | 11:52 PM
mkane's Avatar
Thanks for that. I like the feeling, and the outside edge will also. Auto x on the 14th.
Old Jul 4, 2012 | 12:00 AM
ask the other people at the auto x what their alignments specs are. you'll see a lot of -2 to -5 degrees of camber.
you may wear tires because your toe is off.
Old Jul 4, 2012 | 10:35 AM
mkane's Avatar
Not sure I can get that much out of the fit.
psamtik
3rd Generation GK Specific Suspension & Brakes Sub-Forum
May 12, 2019 02:04 AM
azopelnut
Nov 7, 2018 03:12 PM
hondahazard
Nov 30, 2012 06:31 PM
secondspassed
18
Jul 20, 2011 08:36 PM
Illmatic07
20
Jun 12, 2009 04:16 PM
