Honda Fuel/Road Test
Old Jun 23, 2013 | 10:58 PM
DSx415's Avatar
Just wondering if anyone has done a road/fuel test on their Fit for low mpg at the dealership? Is this test covered under the warranty?
My 2012 Fit Sport has been getting 18-22 mpg mostly city driving ever since I bought it...
Old Jun 24, 2013 | 12:59 AM
13fit's Avatar
check your tire pressure, run 34-36psi at a minimum
stock dunlops are rated at 40psi max, and that is what my fronts are currently. backs are at 37psi currently
These pressures are checked after the car has been driven awhile, tire pressure increases with car use (heat expansion)
I usually average 27mpg with 80% city and many many minutes of idling each day
EDIT its Texas, so the AC is on 100% of the time nowadays
Old Jun 24, 2013 | 08:48 AM
Steve244's Avatar
Take the road down to San Jose (do you know the way?) Loaf along at 65mph. Even with the A/C on you should be in the low-mid 30s (mpg). Report back.
Clear the trip miles before starting out so the avg mpg display is initialized as well.
Old Jun 24, 2013 | 09:02 AM
boatfloyd's Avatar
You need about 6,000 miles on your Fit before it gets better MPG.
Old Jun 24, 2013 | 10:16 AM
flash75's Avatar
I haven't noticed any difference in mpg after 6k miles. After 500 miles , maybe a little improvement. There is nothing special about a Honda Fit that should require 6000 miles for break in.
Just my experience on the Fit compared to other cars I have owned from new.
If you are doing most of your driving on Frisco streets that mpg is probably about average. I live in a small city with some hills, I have to go through 18-20 stop lights and some stop signs a 11mi drive I frequently use. If I use that run and nothing else I get about 24-27mpg. On extended runs only I get 36-39 mpg. That will vary based on how many hills I encounter.
Car is A 2011 Fit Sport with automatic.
Clifton
Old Jun 24, 2013 | 01:00 PM
DSx415's Avatar
Thanks for the replies guys.
I have a little over 8,000 miles on my Fit.
The gas mileage did slightly improve after my first oil change since the dealership used synthetic oil.
Even though I live in SF, isn't getting 18-22mpg really low especially since I don't use AC at all in this city?
It seems the majority of the members here are getting like 27-30 mpg city driving with a heavy foot.
I guess I'll try setting all my tires at 35psi and report back.
Old Jun 24, 2013 | 01:24 PM
Steve244's Avatar
Do your own test: Reset the trip odometer (resets the AVG MPG display). Take an hour's drive down the interstate (I280). 30 minutes each way. Drive leisurely. If you're below 28mpg I'd say have it checked.
As long as you're at or a couple pounds above Honda's recommended pressure (not the max pressure embossed on the side of the tire) you won't see a big (or even noticeable difference) increasing the tire pressure.
MPG of 18-22 is below average for city driving, but then you don't live in an average city. Take it on the highway for a bit.
Old Jun 24, 2013 | 10:08 PM
DrewE's Avatar
How long are your trips on average? If you make lots of short trips (which, with 8000 miles accumulated in a year or so, certainly sounds possible), you'll get relatively abysmal gas milage because the engine is spending a lot of time operating when it's not fully warmed up. The terrain of San Fran is hardly typical of many cities, too, which can certainly also be a consideration.
I concur with Steve's suggestion. Take a longer trip at a steady 65-70 mph and see how the car does.
carolina_cruising
Mar 26, 2014 12:58 PM
Grinder12000
Sep 26, 2012 06:12 PM
matrix02
Jul 28, 2009 08:04 PM
txmatt
Mar 28, 2009 01:12 AM
KnifeEdge_2K1
Apr 20, 2007 05:17 PM
