2010 Fit A/C Clutch bearing failure
Old Oct 28, 2013 | 05:52 PM
d50erock's Avatar
IS it common for the A/C clutch bearing to fail with under 90k miles on the engine? It hasn't seized yet but it's about to for sure. I verified it is indeed this bearing that is going. I have 88k miles on the engine now and it had started getting noisy about 10k miles ago. Seems premature that the AC compressor clutch bearing is failing before the cars 1st break job!!!
Old Oct 28, 2013 | 06:34 PM
13fit's Avatar
If under warranty, take it in ASAP
Old Oct 28, 2013 | 07:32 PM
d50erock's Avatar
Out of warranty
Yeah it was out of warranty back at 36k miles. LOL.
Old Oct 28, 2013 | 07:37 PM
painterguy's Avatar
Senior Member
I have not seen one fail personally and yes under 90k does seem premature for a failure but it could happen.
I would advise you to replace as soon as possible to avoid damage to the compressor snout.
Old Oct 29, 2013 | 03:15 AM
loudbang's Avatar
Yep not a good idea driving around like that. It could fail and cause more damage and mess up the inside of the system with cooling fluid.
Old Oct 29, 2013 | 04:03 PM
d50erock's Avatar
All Fixed
I replaced the pulley and bearing today. I had to buy a used compressor to get the parts I needed. Replacing wasn't to difficult. I did have to use a gear puller, but that was the worst of it. The bearing was shot.
Old Oct 30, 2013 | 01:52 AM
loudbang's Avatar
Good to see someone with the skills to DIY this kind of stuff. Now even so called "mechanics" would just replace the whole thing.
Old Nov 1, 2013 | 12:23 AM
pordy's Avatar
My '07 Accord AC compressor failed before 60k miles.
Old Nov 1, 2013 | 01:15 PM
Spacecoast's Avatar
Can you provide more info as to the process for replacing? How difficult was access, etc. and how did you verify that the bearing was the issue?
Pumpkin
Nov 4, 2017 08:21 AM
TroyGgd3
Oct 26, 2016 08:30 AM
carrier
Jul 1, 2016 07:43 PM
trinisir
May 11, 2015 08:47 AM
MTLian
Sep 7, 2014 01:36 PM
