Code P0970 on a 2009 Fit Sport AT - Possible PCM?
Old Nov 12, 2013 | 07:53 PM
A-Diggy's Avatar
My Fit has been acting up on me in these chilly SF mornings lately. I start it and it goes into limp mode (check engine light + flashing D). I let it warm up, turn it off and back on again and the flashing D goes away...later in the day the check engine light eventually goes away too. I let it fly the first couple times, but it's been every morning lately so I took it into a shop.
They are having a hard time diagnosing it. They checked the solenoid and it checked out fine. They think it might be the PCM.
Has anyone experienced anything similar and come to a solution?
Thanks
Old Nov 12, 2013 | 09:43 PM
2012FitFan's Avatar
I experienced a check engine, flashing D and limp mode. Mine was a 3rd gear pressure switch failure: https://www.fitfreak.net/forums/2nd-...ch-failed.html
Not sure if it's same problem you're having.
Old Nov 13, 2013 | 12:53 AM
painterguy's Avatar
Senior Member
P0970 is a A/T clutch pressure control solenoid valve C open or short.
Old Nov 13, 2013 | 01:30 AM
2010FitSport's Avatar
Just curious why they think its a pcm.
We usually condemn a pcm only after we exhaust all other possibilities related to a failure code and have and found no problems with all of the powers and grounds that go to the pcm in question.
Sounds aloat like they are takingthe lets replace this part and see what happens approach. Ask them what tests they have done that indicate a possible pcm problem.
Lica
Aug 27, 2018 02:52 PM
kitenok
Dec 10, 2015 07:28 PM
A-Diggy
Jul 23, 2013 01:38 AM
Swisst12000
Aug 28, 2012 08:21 AM
les
Jun 8, 2010 11:53 PM
