Suspension Help
Old Nov 29, 2013 | 06:11 PM
dekayfit's Avatar
Suspension Help
Wassup guys, quick question, i am looking to lower my car just a bit but I am not liking the fact that Springs lower the cars rear more than the front. I woukd like the front to be more lower then the front like a Hot Rod. So i was thinking Coili ers on stock shocks and struts, not slamm it but lower it to my perfection about 1"-1.5"... Will it be ok or will it blow my shocks fast?
Old Nov 29, 2013 | 07:16 PM
13fit's Avatar
my dropzone springs were rated for 1.8 front drop and 1.3 rear drop. Never measured it, but my front is indeed lower then my rear.
They are pretty bouncy around town though, maybe Tein or Progress are more your flavor
Old Nov 29, 2013 | 07:43 PM
dekayfit's Avatar
I actually seen Teins S Tech and Eibach Sportlines in person and the Back is Def lower then front. But then again can you or someone explain the Bump stops and should I cut or not?
Old Nov 29, 2013 | 08:50 PM
13fit's Avatar
Do not mess with the bump stops. Cutting them down is very foolish. The few people on here who say its okay must never go over a hard bump at all.
Those bumpstops keep the strut/shock from bottoming out so bad they explode or split, then leak the strut/shock oil all over
Old Nov 29, 2013 | 09:29 PM
dekayfit's Avatar
Well thank you for the info, finally someone actually tells me what the hell it is and does. Once again thank you... Any ither info will be highly appreciated
Old Nov 29, 2013 | 10:33 PM
palos's Avatar
Using any lowering springs will shorten the life expectancy of your stock struts and shocks.
Most coilovers include their own strut, which is why cheap coilovers are typically only for cosmetic purposes, i.e. their struts are of poor quality. (There are generic coilover "kits" that are welded onto the original strut assembly.) For a quality set of coilovers, new struts and shocks will be included, but they are relatively expensive.
Old Nov 29, 2013 | 11:11 PM
I've seen both S-Techs and Sportlines in person, neither spring puts the rear lower than the front. In fact, no springs I've seen for any Fit have done this.
Old Nov 30, 2013 | 01:45 PM
Wanderer.'s Avatar
I have STechs and the drop is even measuring with fingers lol
Old Dec 2, 2013 | 10:52 AM
TERTZA's Avatar
Hey Dekayfit,
If you're looking for adjustability, I'm selling a set of BC Type BR coil overs (used for 1 season) that will work for what you're looking to achieve.
Send me a PM if interested in learning more.
-Terry
Longlivetheking
Sep 26, 2013 02:56 AM
sloganmartin
17
Sep 24, 2012 09:16 PM
teamkitty
May 3, 2010 06:53 PM
aallbbeerrtttttt
35
Nov 18, 2009 11:23 AM
jazz_do_it
Jul 13, 2009 02:31 PM
