Reset TPMS Light 2010
Old Nov 12, 2014 | 09:06 PM
AuctionHugh's Avatar
Question Reset TPMS Light 2010
Just purchased our '10 sport used. TPMS light is on. Seller said she thought there was an easy reset procedure. Is this true? And if so, what is the magic combo?
Old Nov 12, 2014 | 09:26 PM
Hootie's Avatar
Nope. If the letters TPMS is on then there is a system fault which require the Diagnoistic Trouble Code to be read and diagnosed in order to correct the issue. Usually but not always its a matter of having a sensor signal failure.
Old Nov 13, 2014 | 12:16 AM
meaning one of the wheel sensors needs to be replaced, generally?
Old Nov 13, 2014 | 12:39 AM
Hootie's Avatar
In the case of tire pressure sensor signal failure, yes. From the tire pressure sensors I seen, they usually last between five to eight years of service.
Old Nov 13, 2014 | 04:57 PM
Osubeaver's Avatar
If you have an Americas Tie/Discount Tire nearby, they will diagnose for you for free. If the sensor isn't bad and they just need to re-sync the sensors to the car, they will do that for free too!
Old Nov 13, 2014 | 05:06 PM
Thumbs up
That's what I'm talkin' about!
Old Nov 13, 2014 | 06:01 PM
sooznd's Avatar
I have just gone to my dealer an they adjust the tire pressure- no charge. The light comes on about twice a year- when the temperature changes
Old May 31, 2021 | 02:25 AM
Natem21's Avatar
Reset Button?
Got a 2010 Fit Sport and TPMS light is on. How the hell do I reset the light? It doesn't have touch screen radio. Any thought? Thank you.
nbartlet
Aug 1, 2017 12:33 AM
busharroo
Feb 16, 2014 09:37 PM
Vacca Rabite
Mar 25, 2011 11:35 AM
CptanPanic
Jul 28, 2010 04:10 PM
bryanback
May 7, 2008 12:37 PM
