Emergency brake warning
Old Apr 25, 2015 | 11:01 AM
daves007's Avatar
I put the emergency brake on last night, just to clean under the arm. Left it on all night in the garage, backed out this morning and forgot it was on, put it in reverse and noticed in two feet and released it. The light (brake) stays on and it beeps non stop. Drives fine, doesn't seem that the brake is engaged at all. I did a few starts/stops/on/off/rest and it still came right on. As I drive if I push in the button on the handle even without lifting it the beeping stops, light stays on, then will come back on after a while. Any ideas on a fix?
Thanks!
Old Apr 25, 2015 | 11:19 AM
Howdy's Avatar
Did you use any liquid cleaner around the parking handle area?
Old Apr 25, 2015 | 02:30 PM
mahout's Avatar
Thanks!
I suggest you never fully released the ebrake. not that you didn't release the handle but that the mechanism didn't. so pull both wheels and inspect the ebrake parts to see if it did release and if the sensor also indicated correctly.
cold weather and ice will do that easily; did you have rain and freezing overnight?
ps check both wheels even if you think you found the problem on the first wheel.
Old Apr 26, 2015 | 07:11 AM
daves007's Avatar
Thanks for the reply. I kept working it, and it eventually "set"? Drove it around and set and unset the Ebrake a few times and walla, it went down and set perfectly, lights off, warning went off. It just went down that last 32nd of an inch I guess to where it needed to be. Something was preventing it from dropping all the way down. Weird but fine now. Maybe something was stuck in the mechanism of the Ebrake handle.
honestrands
Oct 15, 2021 10:53 AM
nicholasG
Sep 7, 2018 07:15 PM
nicholasG
Aug 2, 2018 10:44 PM
chinkyy
Mar 4, 2013 10:37 AM
Jimmy101
Feb 21, 2007 08:22 PM
