Low Beam Problem
Old Dec 8, 2015 | 08:45 PM
faridango's Avatar
Low Beam Problem
So i left my headlight on for few hours before realizing it was never off. Came back to my fit and battery was dead. After rechargin the battery,
now my left headlight doesnt turn on, and this is HID. so i decide to get stock headlight for temporary til i buy new HID but stock light dont work as well.
Left side(Driver side) headlight,
Low Beam wont work but high beam does
Right side(Passenger side)
Low and High beam work
Any idea why my low beam is not workin on just one side
Old Dec 8, 2015 | 09:59 PM
xxryu139xx's Avatar
did u try swapping the bulbs to the other side. isolate if the bulbs are dead or the ballasts are dead.
Old Dec 8, 2015 | 10:30 PM
faridango's Avatar
Yes i did
both stock 9003 light bulb.
Brand new bulb
Left low beam wont work, but high beam does
right, both work
Old Dec 9, 2015 | 06:31 AM
Black3sr's Avatar
Check fuse 32. It is for right side Low. Fuse 34 for the other side low beam.
Old Dec 10, 2015 | 04:47 PM
faridango's Avatar
Thank you
im surprised they had fuse for each one. My hid system is burned as well..when i put new fuse, it get burn already. When i used stock, it worked
Old Dec 11, 2015 | 12:15 AM
DrewE's Avatar
Are you saying the fuse burns out immediately? Check for a short in the wiring for the right side headlight.
Old Dec 11, 2015 | 03:17 AM
Black3sr's Avatar
Sounds like something fouled up with your HID as the stock light works.
Old Dec 11, 2015 | 04:04 PM
Txfitish's Avatar
What HID kit do you have?
Jim Wagstaff
Mar 21, 2019 04:40 PM
adamnnn
Sep 28, 2018 07:35 PM
Rob Mangelsdorf
Jan 8, 2018 12:17 AM
zaobfit
Nov 22, 2014 09:02 AM
Muster
Jul 20, 2011 05:17 PM
