Driver's door lock stuck in unlocked position - 2010 Honda Fit Sport
Old Nov 13, 2016 | 08:49 PM
ivymae's Avatar
The lock in my driver's door suddenly became stuck in the unlocked position. I can't move the lock switch manually from the inside, the fob doesn't lock it, and the key will not turn in the lock. Has this happened to anyone else? I'm trying to figure out if there is any hope for an easy fix or if I'm going to be stuck spending hundreds at the dealership.
Old Nov 15, 2016 | 12:26 PM
hogwylde's Avatar
I'm curious. Put your key in the ignition (leave it there) and see if you can lock your door.
Old Nov 16, 2016 | 08:13 AM
ivymae's Avatar
I tried it with the key in the ignition, and the lock still doesn't budge.
Old Nov 17, 2016 | 09:48 AM
leurw's Avatar
My passenger side is stuck in the unlocked position. It can be changed manually, and unlocked with the keyfob but will not lock with the keyfob. All other locks respond normally. Huh.
I've got bumper to bump so I'll take it in a let you know. Maybe we are experiencing something similar.
2012 Fit Sport.
Old Nov 17, 2016 | 09:57 PM
ivymae's Avatar
Thank you! Definitely let me know when you find out what's going on with yours.
arkansasfit
Sep 15, 2019 04:37 AM
Justjaymusic
Jul 29, 2019 08:50 PM
upallnight
Jul 9, 2018 11:07 AM
DaveFL
Feb 12, 2014 05:26 AM
whitefitsport
Jun 7, 2010 01:47 AM
