Engine got sound when idling
Old Dec 7, 2017 | 07:28 AM
Adrian Wee's Avatar
Question Engine got sound when idling
Hi guys. Need some opinion. My GE6 Jazz 2009 model MT 180,000km mileage. Recently when the car is idling with air con on or when I moving off and the rpm is low there is a ratting noise coming out from the engine. When driving there is no abnormal sound, engine is smooth. Then I get my mech to jack up the car and the noise is coming out under the engine compartment where the oil pan is. No sound from the clutch side. He open the clutch cover and check clutch is ok. He says needs to open up the engine and check. Suspend crankshaft or the bearings got problem. Not sure of the damaged. Anyone had such problem before? Can the car still be driven and will the engine be damaged in the long run? Please advice. So far engine is running fine without any degrading to the power or FC.
Old Dec 7, 2017 | 02:31 PM
GAFIT's Avatar
Any change in the sound if the clutch is pressed in vs left out?
It could be rod bearings, but clutch throw out bearing is much more likely.
Old Dec 8, 2017 | 02:50 AM
Adrian Wee's Avatar
Definitely not clutch. Press already still same. Went to another workshop tell me is tappet sound. Can live with it.
Old Dec 8, 2017 | 06:04 AM
Adrian Wee's Avatar
But after thinking should not be the tappet sound. More like con rod bearings. Only occurs at idling with ac on and moving off when rpm drops. Then anything above 900rpm sound gone. Engine smooth no sound no vibration. Dunno should I get it fix? Will it escalate to bigger problems? Please advise anyone?
Old Dec 9, 2017 | 01:15 AM
Adrian Wee's Avatar
OK fix done. Went for a third opinion at a slightly more expensive and reliable workshop. The boss told me engine mounting problem. Changed out all the mounting problem solved.
ck42
Jan 4, 2020 04:35 PM
fladed
Jun 2, 2018 12:34 PM
EcoBoost
Feb 8, 2016 06:47 PM
Nvillegas
Sep 30, 2013 11:24 PM
jbolanos
Jun 13, 2007 04:26 PM
