Anyone ever lift their Fit?
Old Apr 3, 2023 | 02:15 PM
  #61
ARCHIVE's Avatar
Originally Posted by mossboss
Great, thanks for your guys' help. Would you be able to suggest reputable online source for the Insight coils?
Try searching salvage yards on car-part.com website
Old Apr 3, 2023 | 06:12 PM
  #62
mossboss's Avatar
If the Insight coils don't come with the spring mounts, can I reuse the ones from the Fit coils?
Item #5 Above
Old Apr 3, 2023 | 10:13 PM
  #63
ARCHIVE's Avatar
Item #5 Above
Not sure on the rubber isolation mounts, I didn't swap them, since I pulled the springs and rubber mounts myself. I bet the stock Fit ones would work. Check part numbers on Honda OE parts sites
Old Apr 4, 2023 | 10:49 PM
  #64
mossboss's Avatar
https://www.hondacarpartsdirect.com/...RzJms9MQ%3D%3D
Looks like the same mount parts for models of that period.
Old Jul 30, 2023 | 06:25 PM
  #65
Mojumbie's Avatar
Hey all, new to the forum, bought a Honda Fit here in Puerto Rico land of potholes, which has had the original springs cut to lower it!...Fashion. I'm gonna have to get new springs anyways, so I'm hoping to lift it. Mine is a 2008, so, second generation I'm gathering? And I see here that the insight springs seem to work on anything second generation or above?
Seems like the consensus is rear insight springs for lift and greater load.
And front insight springs increase load, but you need to add 30mm spacers to level the car, whether you use front fit or insight springs?
Sorry to repeat, I'm just confirming/summarizing all I've read through, and trying to confirm this alteration could work on my 2008.
Besides parts numbers, how do I even find specs related to each models' springs to compare and see if they work together?
Thank you, I'm new to this.
Old May 26, 2026 | 10:03 PM
  #66
Manuel Canario's Avatar
Hey everyone, Spaccer hasn't been able to make front spacers for my 2018 Honda Fit because they lack the manufacturer's 3D data. Does anyone happen to have the 3D data or files to print these front strut spacers?
PS feom PR too
Old May 26, 2026 | 10:19 PM
  #67
PimpFit15
Jan 11, 2012 03:49 AM
J.M.P
Dec 28, 2011 10:37 PM
Zerg
Dec 10, 2010 01:29 AM
Trastan
Dec 10, 2008 02:17 AM
Blazer Deli
Feb 11, 2006 07:04 PM
