Dome light comes on for no reason.
Old Jun 28, 2018 | 01:52 AM
ferulebezel's Avatar
When I am driving at night and make a right turn the dome light comes on briefly and slowly fades. I jiggled the door switches and they all fell the same.
What could it be?
Old Jun 28, 2018 | 06:24 AM
Black3sr's Avatar
did you move the dome light switch as well?
Old Jun 28, 2018 | 08:04 AM
spike55_bmw's Avatar
I'm wondering same thing as Black3sr. The ceiling switch might be "almost" making contact and a bump or turn might jar it enough to turn on the light.
Move the switch back and forth several times and then test it out:
1.) in the normal mode of "comes on when the door opens"
2.) when it is "completely turned off"
Report back on what you find
Old Jul 20, 2018 | 05:46 AM
What could it be?
ferulebezel, what happened with the doom light? Fixed? How? THX
Old Sep 24, 2018 | 01:28 PM
I got busy and got used to it. Now I've noticed that the door ajar light is on and I have to slam the driver's side door to make it go off. I haven't examined the switch so I don't know if it is a replace or a remove and clean situation.
Old Oct 16, 2022 | 11:36 PM
I know this is ancient and I discovered and fixed the problem in ye olden dayes. Nevertheless, here it is. The seat belt retractor doesn't work very well and the tang was frequently getting slammed in the door near where the switch is depressed. The dent made the contact intermittent I fixed it with some neoprene foam and glue.
Manning
Jan 24, 2016 10:43 PM
Vash
Apr 2, 2014 12:10 PM
TWGE08
Jul 28, 2010 03:17 PM
saldivar
Aug 13, 2009 10:54 AM
unphit
Feb 5, 2008 05:47 PM
