2008 fit sport manual - clutch issue
Old Sep 26, 2018 | 08:56 PM
pdub's Avatar
My clutch is not disengaging. There are periods of time it shifts fine and some times the clutch will not not disengage. I recently replaced the master and slave clutch hydraulics but I did not do the damper. It is a separate unit, it is not attached to the master. I went to order one and it appears 46985-SAA-013 is not available at any dealers.
Does any one know of a hydraulic line that will go straight from the master to the slave?
Any insight on what else might cause intermittent clutch issues?
Appreciate your response in advance,
Pdub
Old Sep 26, 2018 | 09:49 PM
GAFIT's Avatar
Pdub
You definitely do NOT want another damper. Clutch works much better without it.
https://www.fitfreak.net/forums/fit-...ardline-5.html
Not sure it will solve your problem though?
FullEffect256
Mar 6, 2019 02:52 AM
gqcpa
Sep 23, 2018 06:04 PM
Mrksstk
Apr 11, 2014 08:43 PM
sean5995
Apr 12, 2012 08:41 AM
rustynail
Feb 16, 2007 03:46 AM
