Starting issue different keys
Old Oct 3, 2018 | 09:03 AM
tyler968's Avatar
Hey, kind of a weird story so stay with me. Typically I use "key A" for driving, etc. This morning (for whatever reason) I used "key B" to unlock my doors and brush off snow. So again, I am going to work. I use "key A" to start, lights come on, all electrical, but no crank. So I was thinking that's really odd, so I decided to use "key B" the one I used to unlock the car, fired up no problem. Is there something wrong here. is this normal?
Old Oct 3, 2018 | 10:17 AM
spike55_bmw's Avatar
That's interesting: My '11 Sport AT doesn't care. Can lock / unlock / start / stop with all combo of the two original factory keys I have.
Old Oct 3, 2018 | 01:40 PM
tyler968's Avatar
ya it was definitely VERY weird...
Old Oct 3, 2018 | 03:56 PM
I have a "skeleton" key (bare metal / no chip) in my wallet to get me through the door if I would lock the keys in there. It also allows me to start the engine but the engines dies in two seconds. Maybe you have a "loose chip" / dead or dying battery. Don't know what to suggest.
Old Oct 3, 2018 | 04:20 PM
tyler968's Avatar
Maybe, that was the only thing I could really think of is battery in the keys.
Old Oct 3, 2018 | 05:50 PM
marmaladedad's Avatar
Is the problem repeatable? And does it occur if you use "A" key to unlock and "B" key to start the car?
Old Oct 3, 2018 | 10:50 PM
tyler968's Avatar
I’ve been trying to repeat throughout the day, I’m going to try my best to replicate
Old Oct 4, 2018 | 08:04 AM
You never mentioned year of the FIT. How old are the batteries in you keys. Doesn't cost that much to put in a new battery. Cold Canadian weather will make a weak battery fail sooner than down south here in the States.
Old Oct 4, 2018 | 11:11 AM
tyler968's Avatar
I've got an 09 Fit, Actually I'm SOOO close to immigrating to Florida.
Old Oct 5, 2018 | 08:39 AM
tyler968's Avatar
I was able to replicate!!! I think I found this issue this morning, the issue wasn't the keys, all of the doors need to be closed. Is this normal?
Old Oct 5, 2018 | 08:55 AM
The car won't lock all "5" doors if one isn't completely closed (will not hear it anything click), so all door remain in the state (locked, unlocked) when you attempt to lock the whole car.
Starting / turning off the engine isn't affected by whether the doors are locked / unlocked / hanging wide open if you have the right key for the vehicle. As I noted, my flat metal key in my wallet will open the driver's side door lock, will turn in the ignition, and will start the engine but the engine dies in a second or two since there is not chip one this key.
Doors needing to be closed t start? Mine isn't programmed that way.
Old Oct 5, 2018 | 09:12 AM
tyler968's Avatar
I found it to be pretty strange and I'm trying to solve that mystery.
Old Oct 5, 2018 | 08:55 PM
ezone's Avatar
Just having a door open should NOT cause a no-crank or no-start issue.
I jump in and out of maybe 100+ different Hondas per week, I almost always have the drivers door open when I start them. Never a problem.
If it were an immobilizer related issue, it would still allow the starter to operate even if an unprogrammed key were used and the green light was flashing rapidly.
Manual trans--clutch pedal safety switch issue, or maybe the floor mat is wadded up under the pedal?
Starter solenoid failing--intermittent click but no crank?
FlipsFit
Nov 20, 2019 05:46 PM
hookerfit
16
Aug 19, 2016 02:46 PM
komark
Jul 7, 2016 08:41 PM
veazer
Jan 23, 2016 08:33 AM
Bishop
Jul 2, 2008 02:40 PM
