Keep or replace
Old Oct 24, 2018 | 05:29 PM
OrangeSport09's Avatar
Originally Posted by knope
With out continuing to beat what's already in essence a dead horse: flip a coin. If you don't like the result, do the opposite.
Hahaha, too funny.
Old Oct 24, 2018 | 05:31 PM
Originally Posted by GAFIT
To expand on the TPMS sensor, they have a permanent battery inside that eventually dies.
I would probably replace all 4 since they are the same age and, in theory, they should last about the same time. If you can coordinate tire replacement with tpms sensor install, you can save some money. I can't advocate for anyone to drive with that light on, but somehow I'm alive after driving many years without tpms sensors. A walk around each morning with periodic pressure checks worked pretty well for decades.
The sensors can be bought from eBay, Amazon, etc for not too much money.
https://www.ebay.com/itm/For-Honda-F...torefresh=true
Will the other light (!)come on still or are they both controlled by the same sensors/batteries?
Old Oct 24, 2018 | 05:34 PM
GAFIT's Avatar
Well, it won't come on if the tire with the dead sensor is low, but I'm not sure about the others. In theory, any working sensor would still send the low signal, but it would not surprise me if the whole system just has a melt down once one sensor stops communicating. In other words, I don't know.
Old Oct 24, 2018 | 07:25 PM
GAFIT's Avatar
I forgot to ask. Is your Fit an auto or manual? If auto, I would lean more toward replace because there is an unknown lifespan with the auto and, without the ability to do your own work, repair can be very costly.
Old Oct 24, 2018 | 07:57 PM
It is automatic.
Old Oct 24, 2018 | 08:00 PM
GAFIT's Avatar
It is automatic.
Well, I'm very interested to see what others think, but that would sway me more toward replace. Maybe someone with a high mile auto Fit will chime in and let us know how long they last or if they last forever.
For me, that mileage on an auto would be a concern.
Old Oct 25, 2018 | 10:30 AM
Well darn, I was just starting to feel like I wasn't in such bad shape and would keep it. If I end up selling, does 4k sound reasonable? (That was middle of KBB range for private party).
Love to hear if other people have luck getting to 300k on an automatic fit.
Old Oct 25, 2018 | 11:51 AM
I wouldn't worry about the transmission if it shifts smooth/doesn't slip.
Old Nov 27, 2018 | 03:03 PM
Well, I'm still plugging along with this car. Went to 2 different locally owned shops, and they actually talked me out of replacing the cc since there are no symptoms (just the engine light). But they will replace it for $550 if I decide to.
So I paid one of them $550 rather than over $800 for maintenance - I think/hope I've found aagood shop to use. I then went to the tire shop and found out I had 2 bad TPMS sensors and 2 nails, so $250ish there.
Now my passenger door lock has this horrible loud grinding sound when it locks. Think it's the actuator? Anyone know what a good price for replacing it would be?
Old Nov 28, 2018 | 05:05 AM
Black3sr's Avatar
Dead battery?
In the sensor itself I assume.
No sensors here in Canada. We have to look at tires to see if inflated or flat. A small piece of black tape over the light and a manual check of tire pressures should solve your problem.
Old Jan 4, 2020 | 10:51 AM
exidor12's Avatar
hey orange sport,
what kind of cat did you get for the $550? are you happy with it?
kyle
Old Jan 5, 2020 | 09:08 AM
  #32
Originally Posted by exidor12
hey orange sport,
kyle
I never replaced the cat. My check engine light still goes on and off, and I still don't have any other symptoms. 244k and going strong!
Old Jan 5, 2020 | 09:13 AM
  #33
For anyone curious, here's the recap:
I started this thread in 10/2018 with 212k miles on my fit.
I decided to keep it, and it now has 244k miles on it.
I never replaced the cat and it's still running fine.
I got the door unhooked from the automated locks rather than replacing it. Just have to lock/unlock that door manually.
Have had no further issues/repairs since!
Old Jan 5, 2020 | 12:53 PM
  #34
exidor12's Avatar
ah okay thanks!
NovaGermania
Aug 23, 2016 04:38 AM
MaxFrames
Jan 7, 2016 08:08 AM
my2007fit
May 28, 2014 09:58 PM
paulfit
May 14, 2010 02:02 PM
hazzard
Nov 14, 2008 02:55 AM
