Your Motor Oil/Oil Filter of Choice
Old Aug 27, 2011 | 09:23 AM
Carbuff2's Avatar
Originally Posted by Black3sr
My dealer will change mine when the MM says to and put in whatever they are selling that day.
That's an important point: Dealers use bulk oil, and it's probably NOT Honda brand.
Old Aug 27, 2011 | 10:37 AM
SilverBullet's Avatar
My dealer said it was oil from Honda in the bulk. It lasts 7500 miles in my car with no oil usage. I talked to the mechanic at work and he was taught that as long as the oil meets the API ratings its designed for that application. It doesn't matter how they made it because the differences are small. I agree with most of it but there are better base stocks and additives and it depends on power output and applications.
Old Dec 26, 2011 | 09:19 AM
nttdemented's Avatar
Old Dec 26, 2011 | 10:01 AM
Honda Oil and Filter, with no problems or oil consumption.
Old Dec 26, 2011 | 02:39 PM
Perrenoud Fit's Avatar
mobile 1 and nappa filter
Old Dec 26, 2011 | 11:48 PM
Red Rockit's Avatar
Mobil1 Advanced Full Synthetic 0W-20
Mobil 1 Filter
8000 interval. Just did my second 16K oil change today.
Old Jan 2, 2012 | 05:40 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
Brand: Mobil
Type: 5W-20 Full Synthetic
Oil Filter: Honda OEM
Intervals: 10,000 miles
Old Jan 2, 2012 | 07:34 PM
GAFIT's Avatar
Brand: Castrol
Type: 5W-20 Syntec Titanium Edge (switched from Mobil 1 years ago since they no longer used PAO base stocks)
Oil Filter: K&N
Intervals: 5,000 miles
Old Jan 2, 2012 | 08:50 PM
Vash's Avatar
Brand: Autozone
Type: 5w-30 sometimes 10w-30 if thats whats on sale
Oil Filter: STP
Intervals: Every 10,000 miles
__________________
Old Jan 2, 2012 | 10:08 PM
The BOM's Avatar
Brand: Motul, Royal Purple, or Redline
Type: 5w30
Filter: Honda OEM
Interval: every 5k miles
BTW, new Honda OEM 5w20 Full Synthetic (in silver bottles) is actually from Kendall not Mobil 1
Old Jan 2, 2012 | 10:49 PM
Mobile 1 full synthetic with Nappa Gold filter
winter 5-20
summer 0-20
change every 5000 miles
A/T Moble 1 full syn. every 12K
Old Jan 2, 2012 | 11:10 PM
  #32
Originally Posted by GAFIT
Brand: Castrol
Oil Filter: K&N
M1 is a tri synthetic and is mostly POA and Group 5, If you look at the PDS Mobil 1 5W-20 you will see the VI is 160. Group III is 120 and PAO is 125 to 150 and Group 5 is 100 to 175. I doubt they use a lot of VI improvers. I have my reasons for not liking M1 as much but it still seems to be a great oil.
Edit for resources: http://www.machinerylubrication.com/...ase-oil-trends ; http://www.peterverdone.com/archive/motoroil.htm I understand its motorcycle and old but still has good info.
Old Jan 2, 2012 | 11:15 PM
  #33
winter 5-20
summer 0-20
I think you got the oil backwards but why not just stick with 0w20 all year?
Old Jan 3, 2012 | 09:30 AM
  #34
GAFIT's Avatar
Edit for resources: Performance of Base Oils and Future Trends - The Evolution of Base Oil Technology - Part 3 ; Peter Verdone Designs - Motorcycle Motor Oil I understand its motorcycle and old but still has good info.
Thanks for the links. Most of my friends run Redline or Royal Purple. I might make the switch to one of them.
I'm running Amsoil in the gearbox and it definitely shift smoother.
Old Jan 3, 2012 | 07:42 PM
  #35
I really like Red line 5w40, it seems to be a great utility oil for all cars and trucks. Now I have to go out and build a car so I can use it. I will check out Royal Purple specifications but someone said it was close to M1.
I know Amsoil is a great oil but don't like its sale techniques, so I will pass on that.
Old Jan 3, 2012 | 07:54 PM
  #36
DiamondStarMonsters's Avatar
Yup good call.
Mike you're gonna want that thinner 0w cold weight for those winter starts!
Might as well leave it for the summer too! Unless your tracking the Fit and go with a 5w30.
Old Jan 3, 2012 | 08:16 PM
  #37
Yup good call.
He was seeing if we were paying attention. I am still thinking a 5w30 is a good oil for all Honda vehicles. My car started on the first spark plug firing. It took 10 minutes to thaw it out though. I use 5w20 Conoco semi synthetic.
Old Jan 10, 2012 | 07:36 PM
  #38
matt1357's Avatar
mobil 1 ow20 synthetic oil
purolator pure one filter
Old Jan 10, 2012 | 08:21 PM
  #39
phenoyz's Avatar
Oil Filter: Honda
Oil: Eneos, 0W-20 Full Synthetic
Intervel: 5,000 miles
Old Jan 12, 2012 | 09:52 PM
  #40
True Adrian's Avatar
found this and thought it was interesting....
Oil Tests
guess i'll be using Honda oil filter and Royal Purple
