Installing studs on rear hubs
Old Mar 23, 2012 | 09:09 PM
thefit09's Avatar
Has anyone installed extended studs on the rears? If so, what's the process?
Thanks
Old Mar 3, 2013 | 03:02 AM
BMW ALPINA's Avatar
Thanks
I am also thinking of installing extended studs on the rear.
so if anybody knew, please kindly post it here.
Thanks
Old Mar 3, 2013 | 10:39 AM
Jodele's Avatar
The proper way is with a hydraulic press…
But I have heard of guys grinding off the stud at the flange of the hub (put a washer over the stud to protect the flange) and knocking them back with a large punch and a mallet. Then you feed the new stud in from behind and stack a bunch of steel washers or larger nuts over the new stud and torque the wheel nut on backwards (flat side to the washers or nuts) to set it inplace.
wh22366
14
Jul 13, 2024 10:45 AM
Steven Hung
Oct 6, 2016 09:21 PM
Fatfit3
Aug 11, 2012 01:07 AM
score04w
Mar 30, 2011 04:24 PM
Mr08FiT
Sep 25, 2009 07:25 PM
