DIY: Automatic Climate Control Conversion
Old Jun 25, 2014 | 03:45 AM
  #61
camivill's Avatar
Still happy as a clam..
After 6 months of using this Auto Climate Control, I have to say that has made me very happy, and worth the trouble. I don;t have to deal with foggy wind shield or putting down because is too cold or higher because is too hot... or turning the AC on or off... I has made my ride so much worry-less...
I have just made a Self Diagnostic Test and a Sensor Input Display register:
What would D value will be for?
Old Jul 25, 2014 | 03:05 AM
  #62
neng8215's Avatar
What would D value will be for?[/QUOTE]
D value for Ver. software.
Old Jul 25, 2014 | 04:42 AM
  #63
Desmond Lamar MacRae's Avatar
My best friend who's an Acura tech has always done my mods will do this but I have a question for North American owners. Why not use the Fit EV parts. Damn I just answered my own question. The EV dash isn't black.
Old Aug 4, 2014 | 09:02 AM
  #64
camivill's Avatar
Ev parts
I tried to check for second hand parts, but there are no many EVs crashed for pieces to flow cheap..... Brrrrr
Old Aug 6, 2014 | 11:10 AM
  #65
ViRStephen's Avatar
Hi Connor55, Camivill,
i'm from Malaysia, after read the great guideline from Connor55, just worried that whether need to cut any existing harness? My car still under warranty, it will void if cut any existing harness or modify existing harness.
I having a set of JDM GE8 2012 RS Dashboard completed full harness with all sensors & blower, is that can be direct use existing sub harness to connect RS Dashboard harness?
Old Aug 28, 2014 | 01:58 AM
  #66
camivill's Avatar
.. no cut
well you dont really have to cut it...
as Connor explained you can keep all the original connectors and all, so u "can go back" anytime...
The reason why Connor took the non existing parts from the Harness, so you can make some sort of link, between the connections not existing and make a "bridge" between the parts added to the system...
If you are afraid for guarantee, you perhaps can ask your dealer about if any wiring change will revoke or wait until your car passes the Guarantee...
Old Sep 1, 2014 | 03:06 AM
  #67
ViRStephen's Avatar
Thanks Bro Camivill's reply, i will try to use the harness of JDM RS Dashboard(non-existing harness) for conversion. Is there whether can work by install full JDM dashboard harness(non-existing harness) to replace my existing dashboard harness?
Also have a important question on A/C ECU, is the A/C ECU of Digital Auto Climate Control same with my existing A/C ECU of Mechanical Climate Control? As i never saw this ECU part from Connor Guideline.
Old Sep 4, 2014 | 03:24 AM
  #68
camivill's Avatar
ECU - Harness
ECU(Electronic Control Unit)电子控制单元,又称“行车电脑”、“车载电脑”等。从用途上讲则是汽车专用微机控制器,也叫汽车 专用单片机。它和普通的单片机一样,由微处理器(CPU)、存储器(ROM、RAM)、输入/输出接口(I/O)、模数转换器(A/D)以及整形、驱动等大规模集成电路组成。电控单元的功用是根据其内存的程序和数据对空气流量计及各种传感 器输入的信息进行运算、处理、判断,然后输出指令,向喷油器提供一定宽度的电脉冲信号以控制喷油量。电控单 元由微型计算机、输入、输出及控制电路等组成... Conclusion is the same ECU you have in the car now...
The Harness is long, big, full of connections and the harness goes in spiral, going intertwined the structures of the dashboard, which will means to disassemble the whole dashboard so you are able to change it.... Honestly i thought about it, but at the end is easier just to do as Connor did....
Old Mar 13, 2015 | 01:19 AM
  #69
connor55's Avatar
Yes, there's no way in hell I was gunna replace the whole harness. It's not bad to just tap in those 10 or so wires.
After nearly 2 years everything is still working fine and no problems whatsoever. I actually forgot that this was a mod after a while lol.
Old Feb 23, 2016 | 06:02 PM
  #70
dwtaylorpdx's Avatar
Dang that is a 10 banana job on the shade tree howler monkey scale..
Old Nov 8, 2016 | 10:00 PM
  #71
eby's Avatar
eby
big thanks to connor i already done with my convert to auto digital climate control
Attached Thumbnails DIY: Automatic Climate Control Conversion-img_1246.jpg   DIY: Automatic Climate Control Conversion-img_1297.jpg   DIY: Automatic Climate Control Conversion-img_1460.jpg   DIY: Automatic Climate Control Conversion-img_1461.jpg   DIY: Automatic Climate Control Conversion-img_1465.jpg
Old Nov 8, 2016 | 10:12 PM
  #72
connor55's Avatar
Amazing work! I cant believe you took out the whole dash, but its definitely a cleaner job than what i did!! It looks great! Hope its working well for you
Old Nov 8, 2016 | 11:51 PM
  #73
eby's Avatar
eby
not connor its all because you inspire me thanks man
Old Jul 3, 2017 | 11:18 AM
  #74
connor55's Avatar
More than 4 years since installing. Car is just over 5 years old now. Not a single problem with this knock on wood of course!
Old Jul 19, 2017 | 10:46 AM
  #75
PaceP's Avatar
Now THIS is a cool DIY!
Old Jan 17, 2019 | 03:44 AM
  #76
ViRStephen's Avatar
I still no dare to install since every parts was ready...
Old Feb 13, 2019 | 04:34 PM
  #77
Fiting's Avatar
Fantastic mod!
Old Oct 18, 2019 | 06:20 AM
  #78
edefer63's Avatar
Guys,
Anyone knows where can I get a 79601-TF0-G61ZC or 79602-TF2-G51ZA?
Thanks in advance.
Old Nov 29, 2021 | 04:27 AM
  #79
Azhar's Avatar
Indonesia of television
Old Nov 23, 2022 | 12:57 AM
  #80
rgibson89's Avatar
Parts ready
Harness and AC control unit from a crashed car from Taiwan ( lucky me) I have amber lights inside so the blue light version was not an option for me, the rest of the components were outsourced directly from Honda distributors south of China.
I am a foreigner living in Shanghai China, so the main point was to get the used pieces, the problem is only the High end FIT comes with this unit, so there is no many sources to get this here in Mainland, rather common in Taiwan... the other parts are cheap originals, as they are made here, except for the Transistor and the Sensors which are Imported from Japan ( high tax) still worth the expense...
Thanks Connor.
@camivill do you have a link or website to order GE8 parts from China? MostCanadian GE8s we’re made in China.
vinnymac
Nov 11, 2010 07:44 PM
vinnymac
Oct 31, 2010 10:22 PM
robcollins5
Apr 8, 2009 03:20 PM
kamakurakid
Feb 19, 2009 12:00 PM
mimpi
Nov 27, 2006 10:15 PM
