DIY Headunit,Amp,Subwoofer guide by Vash **Lots of Pics**
Old Jan 2, 2012 | 12:23 PM
Vash's Avatar
EDIT: UPDATE OF THIS FIX CONCLUSION ON POST #22
Originally Posted by Funkster
Look at the first picture I posted. That is your exact setup then. That is how to wire a dual 4ohm voicecoil subwoofer into a monoblock amplifier at 2ohm.
You never had a 2ohm subwoofer, you can't change that value. You were looking at a picture of a subwoofer that is internally different than yours. You were wiring with an incorrect schematic.
yeah i know what you posted is the same thing. i just wanted to post all of the options to verify with you guys that all i was doing was correct this time.
thanks for all of your guys help.
Old Jan 2, 2012 | 07:34 PM
Vash's Avatar
JUST GOT BACK FROM WORK!!! OMG yes it is MUCH louder.. i took out the battery so all of my settings reset.. i put them back to normal and it is like 50x louder, like even the whole tone is different, iam going to have to mess around with all of my settings again..
its it plays 10x louder and plays a wider range of bass notes, it truely is like night and day!!! i thought it was no difference at first because none of the bass boost was up when i pluggged it back in my car.
realistically... i had the bass boost on about 75% last time.. and its making the same sounds at like 10% now... even louder.
FIXED and rewired to this configuration
Old Jan 2, 2012 | 09:25 PM
Funkster's Avatar
Glad everything worked out.
Old Jan 8, 2012 | 12:46 PM
lowered_klass's Avatar
Excellent write up. It's threads like these, that are honestly priceless when it comes time to tackle projects by yourself.
Eventually I want to upgrade to a double din headunit, and would love to be able to do it myself. I used to always do my own stereo installs, but Im still a bit gun shy as the car is brand new lol.
Old Jan 11, 2012 | 03:21 PM
carneyman's Avatar
I cant even figure out how to get the stock radio off to get at the wires, any tips?
Old Jan 11, 2012 | 09:28 PM
Vash's Avatar
i stuck my whole head under there to get a good look at where the screw was
Old Jan 11, 2012 | 10:47 PM
Goobers's Avatar
yup, that was a pain in the ass.
Old Jan 19, 2012 | 05:55 PM
carneyman's Avatar
Am I missing a bolt or anything? or is it just held in by clips?
Old Feb 13, 2012 | 08:15 PM
Sooner97's Avatar
Thanks for the write up, I plan on upgrading my entire stereo soon and this DIY will help me immensely. Thanks!!
Old Feb 24, 2012 | 01:22 AM
raiderfit's Avatar
Nice write up and great pictures. Can't wait to upgrade my fit.
Old Mar 12, 2012 | 10:29 PM
ill_eagle94's Avatar
How did you get the passenger SRS indicator to plug in. The factory harness for mine just isn't long enough to go from my non navigation indicator location to the new location like yours. I included a diagram to show what I mean.
Old Mar 12, 2012 | 10:32 PM
  #32
Sooner97's Avatar
There's enough slack for it to reach, it may be that the wires are tangled in the back. Try to separate the wires and you should have more then enough room to reach the new point of connection.
Old Mar 12, 2012 | 10:36 PM
  #33
Mine are wrapped together, maybe I just need to separate the loom more? I was hoping I could leave the light unplugged, but my airbag light is on now, so that's a no-go...
Thanks, I'll pull her back apart and see what I can do!
Old Mar 12, 2012 | 10:42 PM
  #34
Sooner97's Avatar
If I'm not mistaken, the plug for the Airbag and Hazard were tied together and you need to separate them in order for the airbag harness to reach.
Old Mar 13, 2012 | 05:26 PM
  #35
Thanks guys, I didn't look closely enough when putting it back together. It was just some foam and electrical tape holding them together. All set now!
Old Mar 21, 2012 | 10:03 PM
  #36
jm95286's Avatar
This was the first time I have ever done this and I wanted to give my thanks to the following members on this forum who helped me:
circa40
Fit4Spl
FittedonEm
V-fit
B-Blue
1SickVeisideZ
kman
I wanted to make this long DIY because I had alot of mistakes even WITH alot of help, and I ended up finishing the install so perfectly... it feels that its more then professionally done... the grommet is air tight.. and there is no damage on any products... also all wiring was still hiden and tucked for a stealth installation.
Now to start....
I bought a VX401 from Crutchfield, and it came with the Metra wiring harness, antenna adapter and the faceplate with various overlay frames for the headunit.
Wiring the wiring harness to the adapter to connect to the OEM harness was the first thing i did. I followed the color code instructions carefully BUT on the adapator harness there is a blue/white wire that needs to be left OUT unless your honda fit came with a stock Amp sire to the harness (which none of the fits do) . So you wire that one to a really long wire that goes all the way to the Remote terminal on the amp (i found this out the hard way because the amp wasn't turning on when I finished up everything)
Its personal preference, but I used the wire twisting and soldering way, and I used shrink wrap to cover up the solder and unshielded parts:
The Amp kit I used specifically was:
db LINK PK4Z which is a 4 gauge amp wiring kit, it came with a really long skinny blue wire which i had no clue what to use it for... untill none of my amp stuff worked and I realized you needed a Remote wire plug in, which I soldered to wiring harness for my clarion head unit, and NOT the adapter.. because the adapter to the honda leads to the car and not to the head unit for the blue/white wire. The wire on the harness should be a white/blue and the one that came with my kit was a solid blue.. it was kinda confusing because antenna wire is also a solid blue....
I prepared the headunit next and I did it wrong the first time, putting the brackets on first and this is what it looks like done incorrectly:
Thankgod for this forum that i did not start grinding and sanding anything because your supposed to mount the brackets first like this, and it will fit perfectly:
The Clarion headunit also has stamped sides, so the screw mount locations are deep and it was TOO deep for the metra screws to make it.. I went to Ace hardware and got the shortest 5M screw available and it was the exact length i needed to screw in the Metra bracket plates
I then put the sub on the box, using a #8 wood screw (i wanted to use 6, but we had 8's laying around the house)
My specific sub is the Clarion 12 inch 4ohm DVC, I used a 4 ohm because I am wiring it in series which will drop the Ohm down to a 2 Ohm.
I then mounted my Amp, which I ended up using a MB Quart FX1.600
In this picture i also used the rubber surrounding of the Clarion woofer. I ended up predrilling the holes into the box, and then putting the rubber surrounding on, and then lifting up the rubber peice and putting the screws under it.
I used all the terminals that came with the Amp wiring kit, they were pretty simple, you just had to strip the wire, putting the copper wire into the terminal and clip down the ends with a plier.
These next 2 pictures are kman's pictures.. but it helped so much with the installation... the hardest things to do are this... taking out the plate below the vending switch
http://farm5.static.flickr.com/4014/...3daac12619.jpg
and then finding that screw next to that white looking vent plastic peice to unscrew.. which is a 7mm bolt or a philips screw driver... you need a LONG one.. i had a PC tools kit that had a screw driver long enough to get to that location to unscrew it... i was REALLY lucky because my dad's tool kit had really long screw drivers and none of them were long enough:
http://farm4.static.flickr.com/3409/...7c1706cfb0.jpg
kman's first post is just.... unbelievably helpful in taking out your headunit.. and installing it back on is just doing the opposite direction.
https://www.fitfreak.net/forums/2nd-...-ge8-pics.html
I personally pushed in and finished up my headunit last..
I did my battery next.. it was a simple, create the terminals with the wiring kit, and it goes in the order of:
1. Battery
2. Wire
3. Fuse
4. wire
5. Thru the firewall grommet
6. towards the back of the car
7. Amp.
I took off my cold air intake to throw a philips screwdriver into the grommet to make a small hole.. and slowly used larger tools to open up the hole large enough to fit the wire in.. On this forum someone gave the advice of using WD40 so that it would glide easyer.. and it worked like a charm.... because i think if you DON'T use WD40 you will just create so much friction and open up the hole really wide... but the the rubber is really hard and tight, so if you use WD40 and glide it thru, the rubber would keep it air tight still... i wouldn't use and exacto knife because the rubber won't retract and be tight if you gave it a cut.
I ended up zip tieing down the 4 gauge wire into 2 different locations.
I ran the rest of the red power wire to thru the driver side door sides, and i tucked the wire underneath the plastic, I took off the plastic panel where the driver side seatbelt was to make the tucking a bit easyer.
As for the passanger side of the car, i ran the RCA cables.. which is what is recommended by Crutchfield and a few other guides to put the RCA on the opposite side of the power:
for the RCA lines from headunit to amp, you just gotta drop the glove box, as if you were changing your cabin air filter.. so just open the glove box and push inwards on the sides on the glove box, and it will drop down to its farthest position, from there, i ran remote amp turn on/turn off wire and the RCA Red and white Wire down the side into the glove comparement, and then to the side where the door is, and tucked it all under the plastic. it is completely stealth with everything closed up:
My headunit has a parking break feature to enable DVD driving play.. but the problem with JUST grounding it to by pass it, is that it won't trick the headunit unless it goes on and off.. some units are able to just be grounded and it will ALWAYS work... but this one is tricky... I ended up using a toggle, switch and screwed one line down to one of the milliion scews you can use as a negative on the frame of the dash ONTO a toggle switch.. (like a 4 dollar one from autozone one) and had the other line leading to the headunit's wiring harness.
For the ground for the amp, i used that bolt with a hook thing on it in the hatchback
With the amp and everything wired up with the ground, RCA, Remote turnon and off, my amp also came with a controller for the bass.
I ended up putting it here using a wood block behind the plastic dash, and there was a hole underneath it, so that i did not have to put any holes into dash at all..
Tucked in the rest of the wires behind the plastic trim... and just close up the headunit...
First time I ever done something like this... I have done suspension and forced inductions several times.. but never audio...
I just hope this guide helps someone, thanks for reading.
Heres the stuff I used in my installation:
Hey, had a question about the headunit you installed. was this car originally set up with the navigation or did you just swap it out? If so, did you just buy the center pannel for the honda fit nav and the brackets? Also when buying the aftermarket, i wanted to go with a single din, is there certain dimensions that you have to have or is it pretty much standard that it will fit or come with a few adjustable harnesses so it will fit? I wanted to start my search for a single din that suites me. Thanks a bunch
Old Mar 21, 2012 | 11:28 PM
  #37
Funkster's Avatar
Are you serious?
Please either delete all of those pictures or unquote the original poster. That is completely absurd.
Old Apr 17, 2012 | 01:57 PM
  #38
Vash's Avatar
Are you serious?
lol, sorry i havent been on the forums in a while, yeah i had the regular sound system that was NOT navi. and it the center control comes with the kit from where i ordered, it just a regular metro kit and it comes with adaptors that allow you to do single din as well. You also get like 3 or so trims around the din as well so you basically just pick and choose which one you see fits perfectly. i used the one that sits flush.
the brackets that come with the metro kit is the pisc i posted where i said i ALMOST grinded and sanded down. those are the brackets, and you install them on the console FIRST and then you put the stereo in and put the screws on.
the screws that came stock with the metro kit are soooo short, i had to go to Ace hardware and buy the same exact ones but a bit longer. Its because the specific stereo din i was using had like caved in puts to where the screws are put on, other manufactures like pioneer has those screw holes like flush with the plates, so it is able to reach.
Sooooo if your going with clarion you might need to buy new screws to fit the brackets because of how they are gapped in.
Old Jul 14, 2013 | 11:40 AM
  #39
kostar's Avatar
Very cool, I am looking at doing this myself soon
mrob
Apr 29, 2022 08:14 PM
StewMJC
Oct 4, 2018 12:41 PM
FightingChance
Feb 16, 2013 11:49 PM
xwikedonex
May 25, 2008 11:19 PM
gd_shane
Aug 9, 2007 09:05 PM
