GE8 Lowered Thread - Post your pics!!!
Old Oct 29, 2014 | 12:57 AM
  #2061
Burzpaw's Avatar
FitFreak Community Team
Attached Thumbnails GE8 Lowered Thread - Post your pics!!!-15023910953_217107b1b5_c.jpg   GE8 Lowered Thread - Post your pics!!!-15653510541_3703ab596c_c.jpg
Old Jan 15, 2015 | 02:47 PM
  #2062
WolfOfTheStreet's Avatar
Let me post my GE8 on TEIN S-TECH with iPhone cam. Poor quality, but who cares
Old Jan 23, 2015 | 04:38 AM
  #2063
Garyman's Avatar
GE6 with Cusco Street Zero A
Old Jan 28, 2015 | 11:29 PM
  #2064
chyno's Avatar
jus showing off my simple FIT
Old Feb 22, 2015 | 03:21 AM
  #2065
ino20's Avatar
This threes keeps me motivated to put money into the fit and not just my other Honda, good work guys!
Old Mar 2, 2015 | 09:57 PM
  #2066
wzlfit's Avatar
megan coilovers -1.5" front almost 2" back. might raise a bit, cleveland streets suck.
Old May 8, 2015 | 02:02 PM
  #2067
eternal_fantasy's Avatar
Lowered on Tein Street Flex
Old May 8, 2015 | 02:55 PM
  #2068
n0thing's Avatar
(Before)
(After)
Progress springs with Koni STR.T struts. Just installed last night so this might settle a little more.
Old Jun 29, 2015 | 12:16 PM
  #2069
rohaansaeed's Avatar
Here's my GP1 from Pakistan on stock suspension.
17 inch 5ZIGEN FN01R-C wheels on 215/45 rubber
Old Jul 8, 2015 | 01:21 AM
  #2070
space egg's Avatar
https://www.dropbox.com/s/qfdp83jq2u..._1109.JPG?dl=0
not lowered but raised! 1/2" above stock (rally style)
195/65/15 (rota slipstreams)
going to drop down 1.25" front and back soon
Old Feb 28, 2016 | 09:48 AM
  #2071
cajlog's Avatar
Hey guys, need some input.
I installed my Tein STECH on 205/40/17 with a ride height of 1.6 front and 1.6 rear, however the front seems to be sitting a little higher than the rears; is this normal ? Should I get them settled in or just have the fronts cut a little bit ?
Attached Thumbnails GE8 Lowered Thread - Post your pics!!!-1-80-3343_what_did_you_do_your_ge_fit_today_80_img_4479_86de5c08ddb4fe8669979049205420a00584ba8c.jpg
Old Feb 28, 2016 | 03:30 PM
  #2072
MEATBABY's Avatar
Are you basing that on actual measurements or just eyeballing it?
Old Feb 28, 2016 | 03:47 PM
  #2073
cajlog's Avatar
Little bit of both but more based on measure actually.
Old Feb 28, 2016 | 07:29 PM
  #2074
MEATBABY's Avatar
Ok, how much of a difference between the front and rear is there? And where/how are you making your measurements?
Old Feb 28, 2016 | 10:56 PM
  #2075
cajlog's Avatar
Here's how I messured the distance and how is set right now:
F = 1.8 inches from tire to fender
R = 1.5 inches from tire to fender.
I've read multiple posts stating the F should settle in a few days but considering how rough the roads are around here, front should have settled already.
Old Feb 28, 2016 | 11:05 PM
  #2076
MEATBABY's Avatar
Three tenths of an inch difference isn't very much. And you say you're measuring from fender to tire? If by tire you mean the top of the tire, that's not the most accurate way to measure. You should measure from the fender to the top of the WHEEL. This will give you a more accurate measurement. Also, are you confident the springs were installed correctly? They do have to be oriented in the struts the correct way (the fronts).
Old Feb 28, 2016 | 11:16 PM
  #2077
cajlog's Avatar
Although measure might not be accurate, nonetheless the Fronts are sitting higher; I might review the installation once again and make sure it was installed correctly.
Old Feb 28, 2016 | 11:58 PM
  #2078
jookybanana's Avatar
Attached Thumbnails GE8 Lowered Thread - Post your pics!!!-80-img_20160227_142129985_hdraa_f73194bf3d446a53d0e029b73aa1cc03daaa2246.jpg   GE8 Lowered Thread - Post your pics!!!-80-img_20160227_142803499_hdraa_b21ddfd5e6916b771c84d5912446fc27e4a6f496.jpg
Old Mar 7, 2016 | 05:22 AM
  #2079
You have same problem with me. I've installed my GE8 on Tein S-Tech and the front sitting higher than the rear. So i cut it a little bit. And now it sit beautifully.
Old Mar 7, 2016 | 01:17 PM
  #2080
cajlog's Avatar
Ditto, this solved the "problem".
