GE8 Lowered Thread - Post your pics!!!
Old Sep 19, 2011 | 03:23 AM
  #1081
dovey's Avatar
Eibach pro kit spring, 205/40/17 +42. do u guys think this will rub? Thanks for helping..
Old Sep 19, 2011 | 05:24 AM
  #1082
90 DGRZ's Avatar
nope, wont even be close.
Old Sep 19, 2011 | 05:27 AM
  #1083
90 DGRZ's Avatar
Originally Posted by FittedOnEm
^ what coils are you on? looks 1000x better in person
thanks! im on megans. nothing is flattering taken with a cam phone at night lol. nice runnin into you the other night
Old Sep 19, 2011 | 09:07 AM
  #1084
SickFit's Avatar
Buddy Club N+ Coilovers
I will be going lower in the front too very soon.
Old Sep 19, 2011 | 10:07 AM
  #1085
SSMTEN's Avatar
ayyeeeeeeeeeee
Old Sep 19, 2011 | 01:58 PM
  #1086
dovey's Avatar
Ok sir. Thanks again. How bout if loaded with 400 to 500lbs? Still wonr rub?
Old Sep 19, 2011 | 08:26 PM
  #1087
90 DGRZ's Avatar
yea, assuming that's about the weight of 3 average men..or you and a couple chubby hunnies in your car, it still shouldnt rub with a x7 +42.
Old Sep 20, 2011 | 12:56 AM
  #1088
dovey's Avatar
^ how bout 38 or 40 offset sir?
Old Sep 20, 2011 | 03:20 AM
  #1089
90 DGRZ's Avatar
2 or even 4mm wont make a diff at all in that sizing.
Old Sep 20, 2011 | 07:00 AM
  #1090
Jaivee's Avatar
Slowly getting there. Here's how she sits now.
Lowered on Swift Springs. 15mm spacers on the rear wheels. Planning on getting either Rota grids +38 or Rota g-force +35.
Old Sep 20, 2011 | 11:12 AM
  #1091
SSMTEN's Avatar
do you have extended studs? i was under the impression that anything more than 10mm doesnt leave enough thread on oem studs
Old Sep 20, 2011 | 04:46 PM
  #1092
Jaivee's Avatar
Didnt get extended studs. The spacers I used are bolt on spacers that bolt onto the original studs, but the spacer also have studs on them.
Old Sep 20, 2011 | 05:12 PM
  #1093
Tong213's Avatar
ive heard scary stories about spacers over 10 mm
do you have any scary feelings driving on them?
any like premonition that something might go wrong?
Old Sep 20, 2011 | 05:30 PM
  #1094
Black3sr's Avatar
Are they like these? Did stock lugnuts fit ok?
http://www.ebay.ca/itm/160636315882?...84.m1423.l2649
Old Sep 20, 2011 | 05:35 PM
  #1095
Jaivee's Avatar
Well so far ive driven 1,000+ miles with the spacers on and i dont feel like they're gunna fall off or anything. I dont get any vibrations or anything. The spacers are hubcentric. Ive been driving the car pretty hard lately because of the swift springs and I'm not afraid the wheels will fall off.
I am saving up for new wheels so once i get +38 offset wheels i will no longer need the spacers.
Old Sep 20, 2011 | 05:37 PM
  #1096
Jaivee's Avatar
Yup thats what they look like
edit: yeah the stock lugnuts fit perfectly
Old Sep 20, 2011 | 06:41 PM
  #1097
Tong213's Avatar
i see, 38 offset on 16s?
Old Sep 20, 2011 | 06:55 PM
  #1098
Jaivee's Avatar
17" wheels with slight stretch on tires. hopefully it doesnt look wierd on the slight drop i have. I'll upgrade to coilovers next year
Old Sep 20, 2011 | 08:46 PM
  #1099
90 DGRZ's Avatar
just to clarify for those reading, if ur using slip on style spacers, you won't be able to put more than 10mm - good rule of thumb is at least 7 full turns on the stud. i believe with stock studs in the rear + 10mm is about 4-5 turns on the stud.
if you're using bolt on spacers (i used to use 15mm project kics) make sure the stud/nut youre using to hold the spacer down clears the back of the rim, or some rims (like rpf01's) have slots to clear studs when youre using bolt on spacers. anddd...stock lugnuts *will* work but you should really use conical lug nuts instead of acorn style nuts so the taper fits snug with the machined spacer. (usually those ebay spacers come with lug nuts to use anyways)
happy tuning!
Old Sep 20, 2011 | 09:16 PM
  #1100
Tong213's Avatar
hmm im curious to see how this turns out!
+38 is flush with 17s?
