is 215/50/17 work??
Old Aug 1, 2010 | 11:20 AM
blackidz's Avatar
Smile is 215/50/17 work??
Hi, I am the newbie in here!!
I do have some question about the rims and tires
is Konig runaways 4x114.3/4x100 with 215/50/17 can fit into my GE without rubbing?
thanks for reply
Old Aug 1, 2010 | 11:23 AM
Btrthnezr3's Avatar
The key is knowing the offset....
What's the offset?
And are you dropped?
Old Aug 1, 2010 | 02:19 PM
blackidz's Avatar
thanks fo your quick reply!
the offset of the rims is +42
Old Aug 1, 2010 | 03:36 PM
Hootie's Avatar
I don't have a GE but I think you will rub like hell due to the tire's hieght and rim's offset with that wide of a tire.
Why is that? Well using Yokohama's S Drive as a base tire, the factory upgraded tire size for GE is a 205/50R16 which has an overall diameter of 24 inches. Switching to a 215/50R17, the diameter will increase to 25.5 inches; this is an 1.5 inch increase in tire size and your car will sit .75 inches taller if it were at stock hieght.
In addition to this, the tire will be pushed outward from the center of the car 11mm more than with the factory GE rims. Also, assuming your car is factory height, the tire's sidewall will be extremely close to hitting the lip of the rear quarter panel. If you had an higher offset somewhere between +45 to +48 then you might be able to pull of a 215/40R17 since the tire's hieght is 23.8 inches otherwise go with a slightly narrower, slightly taller 205/45R17, the shorter 205/40R17, or the even narrower, barely shorter 195/45R17.
Old Aug 2, 2010 | 11:19 AM
blackidz's Avatar
I make some mistake about the offset!
the offset is 40+ with 215/50/17 tires??
How's this setting?? still rubbing
Old Aug 2, 2010 | 12:02 PM
Hootie's Avatar
You'll rub even more because the offset is 2mm lower and the tire is still way too tall.
Old Aug 2, 2010 | 09:30 PM
j1nNju1c3's Avatar
Yes going with a lower offset will cause you to rub more and what he said ^^^^ Tire is way to tall! I say go with 205/40/17
Old Aug 3, 2010 | 01:07 PM
blackidz's Avatar
thanks for all good comment!!
I think I will consider to move to 205/40/17
Old Aug 4, 2010 | 09:08 PM
Klasse Act's Avatar
Unless you lower the car, you'll have waaaaaay too much gap showing. IMO the 205-45-17 would be the way to go if using 17's, although I've seen someone on here with 215's on a lowered car but don't remember his aspect ratio, but it looked great lowered though.
Even if you do lower the car, the 205-45 would still be fine AND maintain a good enough ride.
OldSkoolSi
Aug 25, 2012 07:49 AM
connor55
Apr 30, 2012 12:38 PM
Tong213
Mar 7, 2011 09:31 PM
Halcyon
Nov 25, 2010 07:15 PM
Raaaaaaaaaay.
Nov 25, 2006 06:32 PM
