Clutch pedal return spring failure (18k miles)
Old Mar 25, 2019 | 08:46 PM
ThadCastle's Avatar
Was driving today when I heard a metallic spring noise and a thump in the clutch pedal. Instantly thought of the return spring. I noticed no difference for the next few shifts, but then the clutch pedal would not depress. I would have to let off and try again to shift. When I got home, I noticed that the spring had broken in the middle of one of the loops and rotated forward. This caused the broken spring to move forward (towards the rear of the car) and become stuck behind one of the sensors on the clutch pedal, inhibiting movement when pressing the pedal. With my foot off the pedal, it would sag about 1/2", essentially riding the clutch lightly.
The car is a 2017 with 18k miles. Honda roadside picked it up but they will probably have to order the part. Just an odd and unexpected issue. I was wondering if it has happened to anybody else?
Old Mar 25, 2019 | 09:08 PM
woof's Avatar
We all own CVTs. You're the only one with a clutch.
In all honesty though I don't recall ever seeing a post here about this kind of failure.
Old Mar 26, 2019 | 03:34 PM
ThadCastle's Avatar
So the dealer said the spring cant be ordered by itself and the whole pedal must be replaced. Has to be shipped overnight but is covered under warranty.
Old Mar 26, 2019 | 04:44 PM
evilchargerfan's Avatar
afaik, youre the 1st with this strange issue. good thing youre under warranty
Old Apr 1, 2019 | 03:20 PM
wasserball's Avatar
and I thought this forum was inundated with manuals. Don't they rule this forum?
Old Apr 1, 2019 | 04:32 PM
knope's Avatar
...from the shadows :P
Checking in: 2017 6speed, 60k miles, i've had no issues, clutch pedal included.
Old Aug 5, 2020 | 02:47 PM
Jacob Fassett's Avatar
This just happened to me too. 2018 51000 miles
Old Aug 9, 2020 | 03:17 PM
bill bosco's Avatar
i've never heard of one breaking ,. i did replace two slave
cylinders in 16 years on my last car ( the first replacement was faulty and failed after a few years ) , but no problems with
a spring though . the manual for the car shows that the spring is built around the pedal , so i guess they replace it as one unit
Old Aug 9, 2020 | 09:12 PM
Jazu's Avatar
BB: same here - my first thought was the secondary cylinder (f/k/a the slave cylinder) but ususally the pedal gets soft and stays on the floor when the 2nd cylinder fails. It's a given at 30-60K miles on 2010-15 VWs. First I've heard of a Honda failing - that tells me the part had a defect. Have the dealer inspect the spring or take a magnifying glass and look for "not a clean" break like this:
Old Sep 1, 2020 | 10:21 AM
ogp's Avatar
ogp
I thought I'd post that this just happened to me as well. My 2018 has 29k miles and the spring snapped while my wife was driving the car. Clutch still seems to work normally without it though. Anyway, the repair will be covered by factory warranty, so not a huge deal. Looks like you can buy the complete pedal assembly for $114 (Part No. 46910-T5R-A21) and it's only a few bolts to remove and swap out.
Broken spring.
Other half of spring still attached.
Old Sep 2, 2020 | 12:06 PM
Jazu's Avatar
Springs should not be failing this soon.
Old Sep 17, 2022 | 09:58 AM
wadesworld21's Avatar
this just happened to me! I pushed the clutch, felt a pop and thought wtf .... @44,250 miles in my 2018 Fit
finally crawled under the dash last night and pulled the broken bit and the rest of the spring off the plastic clip. No idea what it is for LOL because i don't really feel a difference in the clutch now, and nothing seems to be affected
Old Sep 17, 2022 | 01:20 PM
BMWguy22's Avatar
Hope this doesn't happen to me.
Only 42k miles, but so far so good.
I have been having issues with it squeaking, which i've been blasting with fluid film (seems to stop the annoying noise!).
Hopefully that'll prevent it from failing.
DoesItFit?
Mar 31, 2019 11:59 PM
p1driftfiend
Jun 27, 2018 10:43 AM
funkdeal
Apr 8, 2016 07:07 PM
oiric2006@gmail.com
Jan 9, 2016 03:01 AM
EMC2
Jul 7, 2015 12:18 PM
