Security system totally LOCKED.
Old Jan 30, 2021 | 01:52 PM
MagicGuitar's Avatar
Somehow my security system is getting turned on, I guess by itself? Anyway the system is locked and trying the lock then unlock has not worked. What to do now?
Old Feb 4, 2021 | 11:29 AM
Jazu's Avatar
I would pull the battery + wire and let it sit for 10-20 minutes to reset the system. I cannot find anyone with a Civic/Fit with this issue on a quick Ooogle search.
Old Feb 6, 2021 | 03:26 PM
Thanks
Thanks for the reply and sorry for not responding sooner. I didn't need to use the FIT until yesterday.The FOB didn;t work and had to use the key to manually open the door. Checking the battery cables I noticed the +cable was loose moved it till it stuck on the post... tried the fob and the car locked and unlocked and most important started up. A few months ago I had a trickle charger installed because the FIT battery is a piece of crap and if I let the FIT sit for more than 4 days the battery is dead. I'm guessing that the nut that tightens the cable wan't tight enough and worked itself loose. Anyway it works, Thanks!
Old Feb 6, 2021 | 04:55 PM
Jazu's Avatar
Good to hear that you're back on the road.
Old Feb 6, 2021 | 05:44 PM
woof's Avatar
My Fit frequently sits for a week at a time and I never have a problem with the battery. I do clean and re-tighten the battery terminals every summer and when I am driving it it's on highway trips which do charge it up nicely.
Old Feb 8, 2021 | 02:00 PM
I should have added - during the COLD months.
Metadata
Feb 14, 2017 06:59 PM
Synycyl
Sep 11, 2015 08:06 AM
japspeed
May 13, 2008 09:46 AM
annie
Jun 26, 2007 02:45 AM
tywen
Jul 26, 2006 09:39 PM
