battery sleeve
Old Mar 9, 2023 | 04:23 PM
Press Fit's Avatar
battery sleeve
I just changed my OEM Fit battery. Does anyone know the purpose of the black corrugated plastic sleeve that surrounds the battery? It's interesting that the sleeve is large enough to surround the larger R51 battery. I'm stunned that my OEM 151R battery lasted almost eight years.
Old Mar 10, 2023 | 09:18 AM
NWCH's Avatar
They are there to help with corrosion and some insulation. I wouldn't remove it.
Old Mar 11, 2023 | 11:28 AM
waldru's Avatar
the use of the black corrugated plastic
Diese Kunststoffleisten sind dafür gedacht, dass die Batterie in verschiedenen Halterungen passt. Wenn Du sie damit montieren kannst, dann solltest Du sie da lassen wo sie sind.
Old Mar 11, 2023 | 03:03 PM
woof's Avatar
My 2018 Fit never had any such thing. I'd guess that it's not essential.
Old Mar 11, 2023 | 06:53 PM
BMWguy22's Avatar
Exactly, couldn't have said it better myself.
Old Mar 11, 2023 | 09:33 PM
2015FITEX's Avatar
it says it all......
i removed mine in the swap
Mister Coffee
Feb 27, 2022 11:05 AM
Jensen Healy
Dec 6, 2019 02:54 PM
HKDM808
Oct 18, 2012 06:24 PM
lnmcmahan
Dec 17, 2010 01:21 AM
revd34
Jul 30, 2009 06:43 PM
