VTC rattle events mitigated with upgraded battery
Old Feb 18, 2025 | 12:36 AM
bobski's Avatar
Originally Posted by nayov
Yeah I don't see acid spillage to be a problem. Back in the day with screw caps and regular water filling, maybe but not with today's so-called maintenance batteries.
I just did the 51R upgrade today - the original 2020 battery wouldn't start the car. It went as planned - even the battery protector sleeve fit the 51R perfectly. I took a pic to compare the two styles of battery tray:
Plenty of debris in the old tray. After finishing the car, I took the tray inside and sprinkled some baking soda on the wet looking residue - it fizzed. Up until the last oil change, this car had gotten nothing but Honda service. While I can't rule out one of them topping up the cells and causing an overflow, you should assume any lead-acid car battery will leak at some point. Even AGM and SLA batteries deserve some caution (mount upright where possible, a tray or even a plastic sheeting "battery diaper" wouldn't hurt).
ruby2009
Jan 10, 2025 12:04 PM
Bubble
Sep 8, 2023 02:25 AM
The_Hoonda_fit
Oct 31, 2019 09:10 PM
FunkTastic
Sep 24, 2019 07:13 AM
staccyyh
Jun 21, 2019 01:56 PM
