MODS/ACCESSORIES for the GK
Old May 4, 2016 | 11:53 AM
  #1361
TofuShop's Avatar
Originally Posted by JinKisaragi
Installed Swift springs + koni shocks. Had to replace my Buddy Club N+ since my fiance and kids don't like how stiff the ride is. Oh well. So now I got a set of Buddy Club N+ (for GE) for sale, driven about 5k miles on it.
Fronts prior to install, looks pretty good with red and orange.
The only install pic I got since it took me 6 hrs to install and I was getting pretty tired, lol
The Buddy Club N+ I now need to sell. Comes with the upper rubber mounts in the rear that I dremeled flat and the front strut bearings.
The hole is elongated for camber adjustment without the need for a camber bolt.
how's the ride height? pics?
Old May 4, 2016 | 03:31 PM
  #1362
BrucesFit's Avatar
I thought buddy club suppose to be close to stock at soft.
Old May 4, 2016 | 11:25 PM
  #1363
TofuShop's Avatar
So i returned my H&R Sport springs to Tire Rack and ordered Ground Controls w/ custom rates instead today. 425# front and 430# rear. Unfortunately since the front spring is so short, that is the softest rate they have available. I've ran a GC/Koni coilover in my old SER and was amazing. I know it'll work well in the Fit as well.
Was hoping to run 300# front and rear so it would be more comfortable.. i hope i won't regret this, haha.
Old May 5, 2016 | 12:30 AM
  #1364
JinKisaragi's Avatar
To me it's streetable. I had the dampers set to 4 from soft. Tried setting t lower but then the car felt extremely floaty. But again, not me complaining, fiancé and kids lol.
But after swapping to the swift/koni, it definitely works better for me on Bay Area California roads.
I took a couple of pics with the swift/koni combo after it has settled and alignment completed. I'll upload it when I get a chance. See below.
Driver side
Driver side rear
Driver side front
Old May 5, 2016 | 09:08 AM
  #1365
jhn's Avatar
jhn
I added weatherstripping from an S2000 between the chin and body for a more OE look. It might protect the paint better at the contact point and the seem looks more consistent. I like it:
Old May 5, 2016 | 05:41 PM
  #1366
BrucesFit's Avatar
Jin looks nice, i'm waiting for my swift spring and imma install it too.
Old May 10, 2016 | 11:56 PM
  #1367
Mr Retro Central's Avatar
Off the top of my head (Aftermarket list)
-Installed-
Volk Rays TE37 KCR BZ Edition 16x6.5
Volk Rays Red Short Type Locking Nuts
Volk Rays Hubrings
Bridgestone Potenza RE003 205/50R16
Cusco Street Zero A Full Adjustable Coilover Suspension
Cusco Centerlock Upper Mounts
Cusco Rear Sway Bar
Tanabe Front Strut Bar
Spoon Front Sway Bar
Spoon Front Rigid Collar Bodies
Spoon Rear Rigid Collar Bodies
Spoon B-Pipe
Spoon N1 Axle Back
Spoon Wiper Blades
Spoon Resivour Covers
Spoon Duracon 5MT
Spoon Windsheild Banner
Spoon Rear Window Logo
K&N Panel Filter
-Not Installed Yet-
Seeker Shifter Box Bushings
GK5 RS Wing
GK5 RS Grill
There is probably more i am missing hahahaha
Old May 11, 2016 | 02:18 PM
  #1368
bladhmadh's Avatar
Today was a cargo cover. I've added Sirius and next will be a hitch followed by a roof rack.
I'm old and boring
Old May 14, 2016 | 02:09 PM
  #1369
COBEs's Avatar
Got a couple of items this week.
A custom sized sun shade.
And this Belkin cupholder phone mount.
Old May 15, 2016 | 02:45 AM
  #1370
ChrisWong's Avatar
Fixes and upgrades
Ground wires from negative to chassis and chassis to engine block were replaced with AWG4 on good lugs properly crimped and well fastened. The chassis side was found covered by paint and the screw spacer was somewhat oxidated and was sanded to shine. Resistance check with dmm Fluke 117 is 0.1ohm.
Improvements: Fuel consumption improves approx. 10%. Sound with stock HiFi becomes crispy clear. Lazy brakes even after bleeding have come back to what it should be.
The stock spring set were replaced with RS R Down #294D from Japan. It reduces the sideward and diagonal movement on uneven surfaces.
Fuel consumption: Hwy better than 43 miles per gallon and 38 for mixed conditions.
Have changed spark plug to Denso Iridium Tough series VFXEH22 for over a year. Physical spec is same as stock. This is my own experiment and good for over a year. Mine is 2015 made in Japan.
Old May 16, 2016 | 06:37 AM
  #1371
YourConfused's Avatar
Originally Posted by chriswong
ground wires from negative to chassis and chassis to engine block were replaced with awg4 on good lugs properly crimped and well fastened. The chassis side was found covered by paint and the screw spacer was somewhat oxidated and was sanded to shine. Resistance check with dmm fluke 117 is 0.1ohm.
Improvements: Fuel consumption improves approx. 10%. Sound with stock hifi becomes crispy clear. Lazy brakes even after bleeding have come back to what it should be.
lol .
Old May 16, 2016 | 04:02 PM
  #1372
Action Jackson's Avatar
Got any pictures of your grounding setup?
Old May 17, 2016 | 07:14 PM
  #1373
Jaeger's Avatar
Deets on the shade?
Old May 17, 2016 | 09:10 PM
  #1374
stembridge's Avatar
Got my car back from the alignment shop after installing RS-R "Down" springs, camber bolts (set to -1.5° camber), rear axle shims (set to 0° toe). Handling is really improved over stock now, and is a hoot to drive. Not too harsh, either (I'm on stock dampers, bushings, etc.).
Also installed a Mugen-style front chin/lip.
Pics in my mod thread.
es
Old May 18, 2016 | 02:49 AM
  #1375
COBEs's Avatar
Originally Posted by Jaeger
Deets on the shade?
Covercraft UVS100. There's a few colors to chose from.
Here's a link to the gold colored one I purchased:http://www.ebay.com/itm/151993318207?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 21, 2016 | 11:56 AM
  #1376
Jaeger's Avatar
^^^^ Thanks man.
Old May 25, 2016 | 01:00 AM
  #1377
Installed a HPS short ram intake over the weekend. The install is straight-foward and easy to do with just basic hand tools. Seems to have a little more midrange power, but it's very subtle.
Pre-install, got the wrinkle black short ram version, there are other colors and you can even get a cold air version.
A few things I didn't like about this intake:
-The hose clamp that goes around the heat shield and air filter was too small. I had to go to Home Depot to buy a 3" hose clamp. Will probably buy 2 more smaller hose clamps for the breather hose.
-The intake piping was kinda rough inside and had some overspray from the paint.
Old Jun 5, 2016 | 03:29 AM
  #1378
LVFit's Avatar
Originally Posted by Brianflys
At the other end of the spectrum....
--OEM Wheel locks
--OEM Applique
--OEM cargo tray (incidentally, my 2009 tray fits, just a tight fit)
--OEM cargo area cover (no seat back snaps on the 2015 model)
from College Hills Honda
Boring, I know...
Oh yeah, California legal tint from local company that did my prior Fit. Soon. It's getting hot out.
Do you have pics or explanation of cargo tray and cargo area cover? Is the cover a hard one or a roll up one?
Old Jun 7, 2016 | 11:30 AM
  #1379
teaisfortiffany's Avatar
Just got my 2016 Fit EX in Aegean Blue on Sunday! So excited!
What are the most essential/popular mods/accessories?
Old Jun 8, 2016 | 12:13 PM
  #1380
Fitster C.'s Avatar
Congrats T. People will probably get tired of my saying it, but all-weather floor mats and cargo area mat will take the edge off using all that interior space. The carpet is not a strong point, and total protection from everything will preserve them, and make anyone jumping in and out with whatever on their feet a non-problem. Enjoy the ride!
