Dashboard alignment
Old Mar 8, 2016 | 05:34 PM
  #41
dwtaylorpdx's Avatar
Plastics warp from heat and cold and sun and.....
I suspect even the perfect ones won't be after a couple years.
Old Mar 8, 2016 | 05:44 PM
  #42
ron3's Avatar
Guess you take your fit like you take your wife (For better or worse) lol. They are a great little car and should easily go 200 k or 10 years with minimal trouble.
Old Mar 8, 2016 | 07:22 PM
  #43
Thats awsome.. I will not however repeat that to my wife..
Old Mar 8, 2016 | 08:25 PM
  #44
Belch's Avatar
I never knew what you guys were talking about with this dashboard alignment problem until I saw these, and that really is not acceptable.
One question I have is what is that square grill looking thing on the dash next to the windshield? It looks like it could be a small speaker, but I'm guessing not.
Old Mar 8, 2016 | 09:09 PM
  #45
Uncle Gary's Avatar
The small square piece next to the windshield is the tweeter for the audio system. The larger opening with the coarse grille located further away is a defroster vent for the side window.
Old Mar 8, 2016 | 09:29 PM
  #46
Belch's Avatar
Isn't the woofer down in the door panel? That's where both the tweeter and woofer is on the JDM models.
and yeah, the defroster is the same.
Anyway, I was thinking that might be a reason for the warpage. Something that wasn't on the original design, but put in there for the American market. I dunno, but that gap is totally unacceptable on a Japanese car. Maybe on a Lada, but not on a Honda.
Old Mar 9, 2016 | 12:20 AM
  #47
If it helps any the CRX had a horrid interior fit and finish, dash rattles, loose bits falling off, seats seldom lasted to 100K.. Honda has a high average but they have definitely screwed the pooch numerous times.. (Passport,,, cough,,, Isuzu)
Old Mar 9, 2016 | 09:35 AM
  #48
Uncle Gary's Avatar
I'm pretty sure the tweeters are in the dashboard on the NA spec cars.
Old Mar 10, 2016 | 05:32 PM
  #49
My 2007 has the tweeter and the main in the doors. FWIW.....
I'm assuming this varies by year?
Old Mar 17, 2016 | 07:51 PM
  #50
Uncle Gary's Avatar
Well. I don't know what to do. I've had the vent trim panel on and off the car a half dozen times to try to position it better, inserted a 1/8 inch spacer under the left end of the dashboard (as shown above), and I still can't improve the fit of the dashboard. No matter what I do, there's still a 1/8 inch gap all around the "A" pillar trim at the base where it meets the dashboard and the vent trim panel. Nothing short of a "A" pillar trim piece larger all around is going to fix this I'm afraid.
I'm at a loss to explain this. At this point, I'm leaning toward it being a case of the "A" pillar trim being shrunken or undersized. Not sure why, maybe a "short shot" or insufficient pressure or wrong temperature of the equipment when molding may have resulted in a shrunken or malformed part (yes, I work in industry as a tool and die designer). Maybe a whole batch of trim pieces were molded wrong. I'm about ready to buy another "A" pillar trim and try that.
sschoe2@gmail.com
Sep 20, 2017 11:04 AM
sschoe2@gmail.com
Sep 11, 2017 11:29 AM
zaebra
Aug 23, 2017 02:02 PM
Michael Raymond
Nov 16, 2015 04:12 PM
skycalen
Mar 9, 2013 01:53 PM
