Ground Connection at Aux Fuse Panel?
Old Mar 27, 2015 | 11:10 AM
m_x's Avatar
m_x
I am trying to add a circuit to the auxiliary fuse panel underneath the driver side dash that will power a 12v socket, and I'm wondering what I can use for the ground connection. There is a bolt at the top end of the fuse panel that looks like it holds the panel in place. Is it safe to undo that bolt and attach the ground wire from the socket there with a ring terminal?
I also read a post were the guy grounded his seat heater circuit to the bare metal plate in front of the steering column, but It seems cleaner to use the bolt on the panel. Is that safe to do? I don't want to melt/burn/blow anything up. Consider this post the FF equivalent of measuring twice and cutting once...
THANKS!
Old Mar 27, 2015 | 08:12 PM
Andy_FIT's Avatar
you can pretty much ground it to any metal part of the chassis, a ground in a proper circuit won't melt anything so you're good.
Old Jan 16, 2016 | 03:55 PM
simonx314's Avatar
I just created a thread with instructions on creating an easy ground point near the fuse box for electrical projects.
https://www.fitfreak.net/forums/3rd-...-fuse-box.html
SilverEX15
Feb 12, 2019 07:25 AM
billydee203
Jan 18, 2016 04:02 PM
SilverEX15
Aug 25, 2014 08:29 AM
colin_f
Nov 23, 2013 04:17 AM
jimnorine
Sep 9, 2008 01:31 AM
