Theory:CVT WOT Power, and how Honda "trick" EPA
Old 04-16-2015, 11:06 PM
GeorgeL's Avatar
I think the GE JDM Fit is advertised as 120PS, which = 117HP?
120PS = 118.4 SAE HP, not 117
Old 07-23-2015, 01:26 PM
i have 2nd gen and i have discoverd this long before readins it in posts.but now i know for sure that double tap technique works for ge8 too.i have a cvt fit hybrid RS.it has 128 hp.and with hps intake and double tap its like a turbo turned on
Old 07-23-2015, 02:39 PM
jukeboxx13's Avatar
Wait so when do you double tap?
What RPM range and is this in sport mode?
Thanks
Old 07-25-2015, 10:11 PM
Myxalplyx's Avatar
When you feel the need to accelerate as fast as possible. Doesn't matter if you are at a full stop or on the highway trying to pass another vehicle.
It doesn't matter what rpm. If you feel the need to accelerate faster and your rpm is not maxed out, let off the gas pedal and hit the gas pedal again. Quickly! Try not to over-think it. You floor it, you say to yourself 'this isn't fast enough', let off the gas and floor it again. The rpm needle will jump up higher rpm rather than waiting for it to get there if you just simply floored the gas pedal. Still not fast enough? Quickly let off the gas pedal and do it again. Sounds like work? Maybe! It'll become 2nd nature after a while. It's not necessary though but if you want to accelerate faster, quicker, than it helps.
You save gas while not doing it. You kick as* when you do. You have the best of both worlds. I don't have a sport mode. I simply drive it in 'D' all the time and do this trick.
Myxalplyx
06-30-2015 09:09 PM
jonno86
03-31-2011 12:06 PM
agcat1981
09-09-2010 08:05 PM
piperpiperpiper
04-21-2008 11:56 AM
mperkel
08-07-2006 10:19 AM
Quick Reply: Theory:CVT WOT Power, and how Honda "trick" EPA
