Picked up 2016 LX this weekend, couple questions
Old May 13, 2016 | 01:27 AM
tonezone's Avatar
Hey guys, I have been luring here and picked up a 2016 LX CVT this weekend. I have a couple quick questions.
1. In the morning I get some vibration noise from what seems like the console area, near the shifter and the cup holder. It seems to fade as the day goes on and I don't hear it anymore by the time I get to work. Any ideas what it could be?
2. Floor mats, there are so many thread... I live in LA, I don't want heavy duty leather ones. The Aries mats seem great but i can't seem to find a set anywhere. Any other carpet or other "good looking" mats you guys recommend?
This place seems great btw, have really been enjoying lurking around and reading about everyones experiences.
Old May 13, 2016 | 06:38 AM
Mainia's Avatar
Don't be foolish and leave your first run factory oil in for 5,000.
Old May 13, 2016 | 07:01 AM
Press Fit's Avatar
Originally Posted by tonezone
The Aries mats seem great but i can't seem to find a set anywhere. Any other carpet or other "good looking" mats you guys recommend? .
I plan to buy these Aries mats:
http://www.jcwhitney.com/p3075663/sk...7692y2016g43j1
Old May 13, 2016 | 07:57 AM
cgs2000's Avatar
What do you recommend?
Old May 13, 2016 | 01:44 PM
Bear Knuckles's Avatar
I love my 3D Max mats. Check my post history. I used to live in socal, it'll get the job done for you.
Old May 13, 2016 | 01:47 PM
tonezone's Avatar
Yeah everything i have seen says to go by the maintenance system in the car, what do you rec?
Old May 13, 2016 | 01:50 PM
tonezone's Avatar
Whenever i bring up the part for my car it shows an image of tans ones for the fronts.
Old May 14, 2016 | 04:21 AM
Bob Levine's Avatar
The factory all-weathers I got fit great and are easy to lean.
Beats Weathertech by a country mile.
Old May 17, 2016 | 07:12 PM
Jaeger's Avatar
Best mats ever.
Old May 17, 2016 | 09:27 PM
GeorgeL's Avatar
The factory oil is special break-in oil. This is rather unique to Honda.
The reason for the old "dump oil right away" philosophy is to get rid of casting sand and machining particles.
Modern manufacturing has eliminated 99% of this debris and anything else will be trapped by the filter.
Don't be foolish and believe net.experts whose recommendations are 30 years out of date.
Old May 18, 2016 | 09:22 AM
cgs2000's Avatar
OK, so you advise that we leave the initial oil in until the computer says to change it? I'm just over 3,000 miles on a new LX and appreciate wise advice. And what brand oil do you recommend?
Old May 18, 2016 | 11:57 AM
exl500's Avatar
The manual indeed says leave it in until the maintenance minder comes on. I choose to do what Honda tells me with the car.
I can't answer your second question because I have the dealer do it.
Old May 18, 2016 | 03:34 PM
Greendog's Avatar
I don't see it there anymore either (although I did order from them and received them after a while... there might be some issues between the two companies. It's been somewhat unclear what was going on and why it took so long for my mats to finally be delivered)
Anyway.... check out etrailer.com I called them and they seemed to be accepting orders on the Aries floormats in black.
Old May 19, 2016 | 07:15 AM
Mainia's Avatar
Like you said motor cleanliness is a non factor these days. My recommendations have nothing to do with that. But you can't stop fresh cross hatch cylinder knock down. What you want to get out of there is the 30 micron an lower that goes right through the filter that comes mostly from knocking down the cylinder cross hatching. Running that grit for 5,000 plus miles is ridiculous. If you drain your oil of a first run oil in ANY car it has a ton of glitter in it. There was a poster in another post that commented how dirty his oil was with fine metal flakes at 989 miles?
Why so many people think Honda is on your side. Honda break in oil has nothing more the a 500 to 600 ppm of molybdenum. I ran a high molybdenum oil like Shaeffer's semi syn 7000 after dumping the first run oil at 500, to 800 miles. There are many other brands of oil that run a high Moly content.
http://www.schaefferoil.com/supreme-7000.html
Or add a Moly additive from this German company to get the Moly you want. One can gives you around 500 ppm of moly. I run a 1/2 of a bottle in all my cars all the time. You can get it at NAPA around $8 a can.
http://www.liqui-moly.us/liquimoly/p...cument&land=US
No other manufacture uses any kind of break in oil. Not BMW, Mercedes, Porsche, Lamborghini, and Lexus. The list goes on and on. And they want you to run it up to 6,000 miles. WHAT? And you sheep do it while thinking you are some car expert on the internet!
I owned a small Audi repair shop so I have a better clue on what I saw/see on first run oil then some of the "want a be" car sleds that follow by the tee what Honda says. All this from a manufacture that made one of the worst AFT fluids known to the industry in modern times Honda Z-1 ATF. And then they told YOU it was a lifetime ATF fluid "No need to drain it." Honda has so many people "snowed " in this weird "we have special stuff" dogma and the "sleds" on the internet forms that just started to pick up a wrench that year keep repeating, because they found the forum for their car, they just keep this weird dogma going and going.
like2cycle33
Sep 12, 2018 10:17 AM
pharmhand
Jan 2, 2017 09:58 PM
max503
Jun 13, 2016 09:26 AM
fitorfat
May 11, 2016 06:51 PM
danorum
Nov 19, 2014 08:38 PM
