How to remove side mirror skull cap from 2015 Honda Fit?
Old Jul 5, 2016 | 12:06 PM
meredithpd's Avatar
Question How to remove side mirror skull cap from 2015 Honda Fit?
Someone clipped my driver's side mirror, busting it at the base - so I have to replace the whole unit. I got a replacement side mirror for cheap, but it's blue and my car is silver. I want to pop off the blue skull cap and replace it with my silver skull cap (which is undamaged.) I've found how-to videos and diagrams for removing skull caps on the previous Honda Fit model, but the clips aren't as easy to find on the 2015 model - only two clips are immediately visible, and they're not enough to release the skull cap. Does anyone know where the other clips are/how to remove the new model's skull cap?
Old Jul 5, 2016 | 03:35 PM
2015FITEX's Avatar
76208-T5R-308 - Genuine Honda Mirror Assy., R. Door (COO)
this might help,
if you look at the parts online you may be able to see where the clips are ?
maybe even ebay ?...for a photo?
its a pretty common part you are asking about i would guess
Old Jul 5, 2016 | 06:25 PM
meredithpd's Avatar
Thumbs up
Thanks for the suggestion, but unfortunately the Honda parts diagram doesn't show where the clips are. BUT I figured it out. In case anyone else has this issue, there are 4 clips - two on top that are the same color as the car, and two on the bottom that are black. The skull cap and the black bottom piece have to be removed together (this was my mistake - I was trying to remove the skull cap independently) by pressing the 4 tabs in simultaneously.
Attached Thumbnails How to remove side mirror skull cap from 2015 Honda Fit?-imag1753.jpg   How to remove side mirror skull cap from 2015 Honda Fit?-imag1754.jpg
Old Jul 6, 2016 | 11:11 AM
Bassguitarist1985's Avatar
WAYYY Ahead of ya bud!
Old Mar 14, 2017 | 02:38 AM
arkmann's Avatar
You don't happen to have saved that blue skull cap by any chance right? Also, do you have instructions on how to remove and install the mirrors?
Old Apr 13, 2017 | 07:39 PM
orataro's Avatar
So, you have to remove the Glass mirror to get to the tabs to remove the skull caps?
Any suggestions? I'd hate to break the mirror.
Old Aug 7, 2017 | 10:16 AM
bloodychoc's Avatar
Seperate the skull cap.
Hi guys,in the yellow circle there is 3 hinges locked each other. Any advice or guidance to separate the top colored and bottom black skull cap? Thanks in advance.
Attached Thumbnails How to remove side mirror skull cap from 2015 Honda Fit?-imag1754.jpg
Old Aug 7, 2017 | 02:45 PM
Action Jackson's Avatar
Once you undo all 4 clips (I used 4 screwdrivers to do this), the cap comes off easily.
Old Aug 8, 2017 | 10:19 AM
Start with the 3 hinge clips first and firmly but gently pry the piece apart.
Old Aug 8, 2017 | 12:12 PM
bloodychoc's Avatar
Okay noted! i did tried to pry the 3 hinges open,but i got scared half way worry it'll be flimsy and breaks. i shall attempt again!
BenQuick
Jun 8, 2023 05:36 PM
jujujenny2112
Jan 25, 2019 05:37 PM
Renaissance Digerati
Feb 20, 2018 12:47 PM
Socialvegetable
Oct 19, 2010 05:49 PM
kodo
Apr 12, 2008 10:56 AM
