replaced my CVT fluid today
Old Aug 25, 2016 | 01:59 AM
wcsmik's Avatar
here are some pics to help out anyone whose looking to replace their CVT fluid
circled in red are where you need to disconnect things to remove the air filter box. 2x 10mm screws, a hose with a clamp on it, and a rubber boot you can just pull by hand.
CVT fluid drain. 3/8 drive.
drain plug for CVT has a magnetic tip. don't forget to clean it off.
captured exactly 3.5 qts.
with the air filter box removed you will see a rubber plug with a metal tab sticking out of it. you just need to pull it out to fill.
use genuine fluid. i just put back in the amount that came out. 3.5 qts.
here it is all put back together
whole process shouldn't take more than an hour.
Old Aug 25, 2016 | 12:34 PM
Uncle Gary's Avatar
Nice garage you have there.
Old Aug 25, 2016 | 01:08 PM
BenQuick's Avatar
Thanks for the write-up. Your engine bay looks real clean. And yes, that is a nice garage.
How many miles did you have on the car before the fluid change?
Old Aug 25, 2016 | 01:39 PM
tsand19151's Avatar
Nice job!! Do you take major credit cards? :-)
Old Aug 25, 2016 | 01:52 PM
jhn's Avatar
jhn
I didn't do it this way. I used a long funnel and I refilled it through the overflow port until it started coming out.
Seems to have worked ok.
Old Aug 25, 2016 | 03:18 PM
wcsmik's Avatar
i did mine at 32k. i periodically use the air hose to clean up my engine bay and wipe down the dust
i knew the fill plug was ontop of the tranny somewhere but i couldn't see it which is why i just decided to pull the air filter box. comes out in few min.
Old Aug 25, 2016 | 06:24 PM
Alco RS-1's Avatar
When I was shopping for my car, I also looked at the Nissan Versa Note. By comparison, changing the CVT fluid in a Note is a complex multistep, unforgiving nightmare. It was one of the reasons I scratched the Note from my list. Nice to see that Honda has a far better process.
(As it happened, I bought a 2013 Fit with a 5-Speed Auto)
Old Aug 30, 2016 | 10:26 PM
salamlaith's Avatar
a 1000 thanks, good job
Old Aug 31, 2016 | 10:49 AM
FitRaptor's Avatar
At 32k? isn't that too soon? I wonder what the manual says. Then again I don't know after all it is a small car with small parts. Seems simple thank you for the write up for future reference
Old Sep 1, 2016 | 01:05 AM
salamlaith's Avatar
did the oil replacement made any deference in cvt operation ?
Old Sep 1, 2016 | 07:39 AM
30k does seem early. keep us posted wat the manual says.
Old Sep 1, 2016 | 08:56 AM
jhn's Avatar
jhn
I changed mine @ 18k but I've been tracking my car at times 100f ambient temps. I just felt better about changing it.
Old Sep 1, 2016 | 10:59 AM
2Rismo2's Avatar
Mine's a daily driver so I'll just change it when the maintenance minder says so. A previous member in this thread went over 80k before it was changed and he used it as a work delivery vehicle: https://www.fitfreak.net/forums/3rd-...ml#post1331172
Old Sep 1, 2016 | 12:33 PM
FitRaptor's Avatar
After closely reviewing the manual I did NOT find anything about the 2016 Honda Fit CVT transmission fluid flush. But what I did find was the maintanace minder/reminder section which stated this:
Follow maintenance reminder:
A is an oil change.
B is an oil and oil filter change & a bunch of inspections.
A and B will alternate.
1 is the subcode for rotating tires and it will always appear on every maintenance interval.
2 replace the air filter and pollen filter and inspect drive belt.
3 replace transmission fluid
4 replace spark plugs and check valve clearance
5 replace engine coolant
6 replace rear differential fluid
So after looking at this then I will just wait for the code to pop up to change the fluid. I mean all depends how you drive your vehicle. I personally don't track or drive crazy on my fit so I will just wait for the (3) code to pop up.
Old Sep 2, 2016 | 05:42 PM
wcsmik's Avatar
honda is not known for their good transmissions.
cvt trannys also tend to run hotter so i decided to replace every 30k. fluid did come out dark and had a slight burnt smell to it.
and yes the fluid change did make the car run alot smoother. i also did a oil service at the same time and added RAN UP oil additive. car runs smoother than ever.
probably not a good idea to follow manufacturer recommended timeline for fluid replacements. especially for engine oil.
Old Sep 3, 2016 | 08:13 AM
A is an oil change.
thanks for checking! yah, i will change it when the obc says its time. might be never cause i never keep my cars more than 50k miles usually..
SilverEX15
33
Jul 21, 2023 01:19 PM
SilverEX15
Sep 4, 2019 05:17 AM
Michael Yount
Sep 13, 2015 05:10 PM
ROTORHEAD77
Aug 2, 2012 03:13 PM
gmbdelsol
Mar 22, 2010 06:02 AM
