Splash Shield - First Attempt
Old Nov 10, 2017 | 09:25 AM
SilverEX15's Avatar
Originally Posted by TorontoBoy
I am sticking with zip ties. They are inexpensive and effective so far.
Old Dec 12, 2017 | 11:41 AM
mateusiv's Avatar
How important is this front undercarriage splash guard? I recently bought my 2015 Honda Fit EX 6MT and later noticed this was missing. With the angled front facing oil filter I’m a little concerned it could get punctured by road debris? Is this a fair concern? The local dealer quoted me $185 before tax for the part, is that reasonable? Sorry guys, noob Fit owner! Any help is appreciated.
Old Dec 12, 2017 | 12:20 PM
some drive without it. $185.. check bernardi parts who is a sponsor here. they
might be able to offer you a lower price.
Old Dec 12, 2017 | 02:37 PM
2Rismo2's Avatar
While it "COULD" happen, I think it's unlikely. I have an SV650 and the oil filter is facing forward, right out of the open and haven't had any issues.
Not my bike, but you can see the oil filter near the front header: https://bobistheoilguy.com/forums/at...9576-sv650.jpg
If you really want the splash shield, I'd check ebay or junk yards. HondaPartsNow has it for about $130.
Old Dec 13, 2017 | 01:46 PM
mateusiv's Avatar
Thanks for the replies! Very helpful. I did find it at Bernardi Pats and HondaPartsNow at a good discount, unfortunately the shipping was about as much as the part itself. I’ll scavenge eBay and see what I can find but for now I guess I’ll keep an eye on it and hope for the best.
Old Dec 14, 2017 | 03:11 PM
wasserball's Avatar
I asked the dealer to leave the undercover off after the first free oil change. Today, I changed the oil and filter without using any lifts because I was able to reach the oil filter and the drain plug with my hand from the front of the car. The most difficult part of the oil change was having to overcome the excessive tight oil plug. Come on dealer, tell me I didn't have to use a sledge hammer on the ratchet to overcome the locked plug. Also the oil filter was excessively tight. The recommended "tightness" is 1/4 turn after the oil filter has seated. All in all, the whole exercise took about 15 minutes, and another minute to reset the oil quality indicator to 100%. I did noticed that the remaining plastic bracket that holds the undercover was loose to which I used some silicone adhesive on the screw before tightening it again. Changing the oil is the most important maintenance in keeping the engine running smoothly and I will change it frequently.
Old Dec 14, 2017 | 03:28 PM
SilverEX15's Avatar
Originally Posted by wasserball
I asked the dealer to leave the undercover off after the first free oil change. Today, I changed the oil and filter without using any lifts because I was able to reach the oil filter and the drain plug with my hand from the front of the car. The most difficult part of the oil change was having to overcome the excessive tight oil plug. Come on dealer, tell me I didn't have to use a sledge hammer on the ratchet to overcome the locked plug. Also the oil filter was excessive tight. The recommended "tightness" is 1/4 turn after the oil filter has seated. All in all, the whole exercise took about 15 minutes, and another minute to reset the oil quality indicator to 100%. I did notice that the remaining plastic bracket that holds the undercover was loose to which I used some silicone adhesive on the screw before tightening it again. Changing the oil is the most important maintenance in keeping the engine running smoothly and I will change it frequently.
It should be common knowledge that over-tightening the oil filter can cause leaks.
Old Dec 16, 2017 | 10:28 AM
woof's Avatar
Are you sure about that 1/4 turn? I have a small case of Honda oil filters ( the A01 Filtechs) and it's stated on them to tighten the oil filter: "about 3/4 turn after gasket contact" which is more in line with what I've seen stated in the past for other cars and filters. I don't have any of the more common (and lower quality) Honda A02 Frams to see what they say.
Old Dec 16, 2017 | 05:36 PM
SilverEX15's Avatar
I've always seen 3/4 turn.
Old Dec 16, 2017 | 05:41 PM
i crank it pretty good by hand.. probably a good 3/4 turn on the filter.
just use the right tools and even the kingkong tight plug and filter will come off easily.
Old Sep 4, 2018 | 07:00 PM
fujisawa's Avatar
GAFit .. so 10mm is the right one? Have been looking but its hard to tell which size is most common on the car ... :/
Old Sep 4, 2018 | 07:18 PM
  #32
GAFIT's Avatar
10mm is definitely the most common. That seems to be 90% of the one way fasteners. I had to buy an assortment just last week because I had a push fastener break that was up in the door jamb/front fender area. That one ended up being an 8mm, but that's the first time I've needed one of those.
I also bought these...
https://www.ebay.com/itm/Performance...72.m2749.l2649
Only used them once, but what a nifty tool.
Old Sep 4, 2018 | 11:17 PM
  #33
Villageidiot's Avatar
With regard to the push clips, a lot of times I will take them out and put nut-serts in the holes if they are metal, then it’s just a body washer and a bolt holding the under trays up. Yeah, takes more time to initially do, and you gotta have the special tool to install em, but they are great.
Old Sep 5, 2018 | 08:09 AM
  #34
SilverEX15's Avatar
Aand on Amazon -
https://smile.amazon.com/Performance...ush+Pin+Pliers
Old Sep 5, 2018 | 09:10 AM
  #35
GAFIT's Avatar
And for less money! Good looking out!
I have a few interior trim tools (I'm a tool junky), but honestly didn't know one existed specifically for these one way plastic push fasteners. It's pretty simple, but works quite well.
TorontoBoy
May 17, 2022 10:58 PM
Chiasson Cary
Jan 15, 2022 09:44 PM
fenixfire077
Mar 4, 2019 01:24 PM
SilverEX15
Oct 17, 2017 05:28 PM
