Plastic shield underneath
Old Aug 26, 2018 | 11:00 AM
captainhowdy's Avatar
Mechanix choice has had fastener assortments....or as Knope says...zippies!
Old Aug 26, 2018 | 08:43 PM
MikeDD969's Avatar
Originally Posted by knope
Indeed. If only such a source could be found... Found it!
SuperUltra Oh Eee Ehm fasteners
<3 lol
Yeah, I found those. I'm just looking for something a little "better" I'm tempted to try nutserts and bolts, if I can find someone that I can borrow a nutsert tool from.....
Old Aug 27, 2018 | 10:34 AM
bzdang's Avatar
They be called Speed nuts or Tinnerman nuts, see wikipedia
and mcmaster.com
should be dozens of styles, common as nails at auto parts stores everywhere.
Old Aug 27, 2018 | 06:49 PM
MikeDD969's Avatar
and mcmaster.com
No, I'm aware of those. That's what's holding on the 6 (or is is 8??) regular phillips-head screws that attach the front and sides of the pan. I have a large assortment of those, picked up cheap from a local hardware store. I'm talking about the 2 plastic push-in rivet thingies that hold the very back onto the steel crossmember.
The more I think about it, the more convinced I am that a "Nutsert" also called a "rivet nut" is the answer. Like these It would allow use of a threaded steel bolt, perhaps a button head Torx, or even just a plain old hex head bolt to be used there. I just don't know if it is worth shelling out the $$ for the installation tool for those. McMaster-Carr is awesome in that they have almost everything you could ever need, and it's all high quality, but they are also very expensive. Other sources have the tool a lot cheaper, probably good enough quality for the very occasional use I'd have for one. I don't do enough fabrication (yet) to justify purchasing one. Hopefully I can find someone locally who has one I can borrow for a day. I think it would be a great solution.
Silkenfit
330
May 23, 2022 08:23 AM
TorontoBoy
May 17, 2022 10:58 PM
georgi6
May 24, 2019 09:18 PM
JM80Fit
Dec 3, 2018 09:49 PM
SilverEX15
Dec 2, 2014 01:36 PM
