Red Temperature light blinking!
Old Jul 10, 2020 | 02:35 AM
Fitting3's Avatar
Recently my temp light started to come on, i checked the coolant and it was a little low in reservoir, i then topped it off to the fill line. Red temp light still blinking i have a 2016, anyone know what can be wrong, does this vehicle have a thermostat i can replace? i hope its not water pump.
thanks,
Old Jul 10, 2020 | 02:49 AM
CVG323's Avatar
thanks,
any leaks ?
my 2013 CR-Z had a bad water pump (leaking) and it decided to dump all the coolant on the freeway lol
Old Jul 10, 2020 | 03:00 AM
Fitting3's Avatar
Originally Posted by CVG323
any leaks ?
Lets hope my water pump is ok,sadly the car is only 4yrs old never had a Honda with so many problems that is so new, might have to get a other crx.
Any other suggestions?
Old Jul 10, 2020 | 03:20 AM
CVG323's Avatar
add some coolant to the radiator
make sure its topped off, then let it idle for a bit while checking the temp.
could be air in the system if coolant was low inn the rad.
Old Jul 11, 2020 | 03:59 AM
Fitting3's Avatar
Thanks friend, that fixed it.. When I took off radiator can there was a hiss so definitely air, it took quite a bit of radiator coolant... topped off let it idle out the cap on and drove for 30mins no temp light anymore.
Thank you
Old Jul 11, 2020 | 05:24 AM
CVG323's Avatar
Thank you
Glad it worked. Sometimes the smallest things cause the biggest problems.
Old Jul 11, 2020 | 09:41 PM
Fitting3's Avatar
Yes indeed, I'm still a little scared and keep a close eye, when I topped off coolant from from radiator spout I waited some 15mins and there were still bubbles coming from it...the bubbles never stopped.
Old Jul 12, 2020 | 11:03 AM
sneefy's Avatar
The question you need to answer is where that coolant went and how did so much air get into the coolant system.
Being a Subaru guy, I would first suspect head gaskets. Not sure if the Fit is phone to that or not.
Either an external coolant leak, or an internal one. Time to investigate.
Old Nov 2, 2020 | 04:31 PM
Fitting3's Avatar
A follow up to the this: Fit still running strong no temp light, has to be internal leak, im in arizona so I wonder if thats a factor with the heat, though where the coolant is at is a contained system. I have notice that I can hear the coolant sloshing around sometimes internally but the temp is not alerting me that it's overheating; I wish there was an old fashion temp gauge on this car, that would be so much better than me waiting for a digital alert. Thanks again .
lschiffer
Jun 3, 2023 01:07 PM
Mister Coffee
Sep 11, 2019 11:58 AM
NotraFit
Dec 29, 2008 02:55 AM
Raaaaaaaaaay.
Jan 13, 2007 06:58 PM
Berto
May 8, 2006 04:11 PM
