Where is the Transmission Dipstick?
Old Mar 29, 2015 | 04:18 PM
osnickers's Avatar
Where is the the transmission dipstick on the HONDA fit 2015?
Old Mar 29, 2015 | 04:46 PM
Redd's Avatar
There isn't one
Old Mar 29, 2015 | 05:43 PM
cheesewhiz's Avatar
On the 6 speed manual it's next to the heart rate monitor.
Old Mar 31, 2015 | 06:20 AM
GoBucky's Avatar
Redd is correct, there is no tranny dipstick.
Old Mar 31, 2015 | 06:36 PM
Helistyle's Avatar
How do you go about checking level or doing transmission fluid changes ?
Old Apr 1, 2015 | 01:00 PM
GeorgeL's Avatar
If you see transmission fluid on the underside of the car or on the ground the level will be lower and it needs checking. Unlike engine oil, the fluid has nowhere else to go and therefore doesn't need regular checking.
Old Oct 21, 2021 | 01:37 PM
myred67mustang's Avatar
Trans does not have a dipstick
Originally Posted by Redd
There isn't one
this trans does not have a dipstick, what it does have is a fill plug on the side of the trans. It is a 17 mm bolt, uses HCF-2 fluid
have included pictures you have to remove lower engine cover same as when doing oil change
Drain plug location 3/8 ratchet will work on this
Fill plug location and fluid tag
Old Oct 27, 2021 | 09:31 PM
Bassguitarist1985's Avatar
How do you drain the MTF when it needs changing?
Old Oct 27, 2021 | 10:25 PM
Drew21's Avatar
Transmission fluid change is no harder than an oil change. Well, maybe a tiny bit because of access.
1) Warm everything up.
2) Loosen the fill plug (you don't want to drain what you can't fill).
3) Get you drain pan in place.
4) Remove the drain plug. Check the magnet for metal. Wipe it clean before replacing.
5) Replace the drain plug and torque to spec.I think there's a crush washer you're supposed to replace (there is on the A/T).
6) Fill through the fill plug using the appropriate fluid until a bit of runs out and drips into your eyes.
7) Replace fill plug and torque to spec.
To answer the original question, if you want to check the level you have to remove the fill plug. The fluid should be level with the fill plug. The manual will tell you if the tranny should be cold or hot when you check (I can't remember off the top of my head). I know you check the A/T level when hot, so it's probably the same for the M/T.
666fit666
Dec 14, 2023 11:24 AM
domromer
Feb 19, 2019 06:37 PM
dvoisawesome
Dec 12, 2017 02:43 PM
kaede1337
Jul 31, 2016 05:22 PM
kcataylo
Aug 23, 2014 10:50 AM
