DannyJ7's Foxy Build
Old Sep 3, 2022 | 06:05 PM
  #121
BMWguy22's Avatar
Originally Posted by DannyJ7
BAM! All the pictures.
Maybe a bit difficult to see, but the LED bezels are on and working. I wired them so they only come on with the headlights. For me, they're just too bright for day use...as stupid as that sounds. Meh, personal preference.
Where'd you get the LED bezels?
They look awesome!
Old Sep 6, 2022 | 11:14 AM
  #122
DannyJ7's Avatar
I believe they were from Ali Express? I did look, can't seem to find them now.
Old Oct 8, 2022 | 01:44 PM
  #123
DannyJ7's Avatar
Did a mini-tune up, I'm only at 55,000 miles, but Foxy is nearly 8:
Changed spark plugs:
Here's what I found as far as procedure for replacing plugs:
  1. Make sure you blow out or vacuum around the coils before removing them to prevent debris from entering plug holes.
  2. Check the gaps. Although mine were fine out of the box, it's worth checking, every time.
  3. If you're careful, you do not need to pull the wiper cowling.
  4. You can carefully insert the socket in most of the way into the plug hole, then attach an extension and make it work, both for removal and insertion.
  5. Be very gentle torqueing the plugs, particularly if you're using anti-seize. 16 ft-lbs
  6. Wear gloves. Though I was able to avoid removing the cowl, I beat the snot out of my knuckles.
Drain and filled coolant:Oil Changed:Used on both:
Old Oct 8, 2022 | 02:02 PM
  #124
DannyJ7's Avatar
They look awesome!
I think I may have found them
Old Jan 15, 2023 | 08:37 PM
  #125
atomicwrites's Avatar
How have the spray painted trim pieces held up? Love how your car turned out.
Old Jan 16, 2023 | 07:48 AM
  #126
DannyJ7's Avatar
Thank you!
They've held up very well minus the bits that get direct sunlight (IE right under windshield) since the rest of the car is tinted and parked inside. In the areas that have gotten sunlight, the cherry red is now more of a darker orange. A good clear will take a bit of abuse as well.
Old Apr 2, 2023 | 11:38 AM
  #127
DannyJ7's Avatar
...Just ordered a 2024 Ecoboost Premium...
Foxy's on the market.
Old Apr 2, 2023 | 12:17 PM
  #128
BMWguy22's Avatar
Thanks for the link.
I've decided against them as I really dislike the hassle of removing the front bumper.
For now, the stock fogs will suffice.
Glad to see folks are still buying coupe's.
Now for the ultimate question, did you order it with auto or manual?
Old Apr 3, 2023 | 08:34 AM
  #129
DannyJ7's Avatar
Ecoboost no longer has the option for a manual sadly.
That said, the intent of the car is to be car for long road trips and sight seeing.
Old Apr 3, 2023 | 12:13 PM
  #130
BMWguy22's Avatar
These days, the performance of the auto is nothing short of remarkable.
I'm sure you'll love it!
Old Apr 6, 2023 | 09:25 AM
  #131
DannyJ7's Avatar
Foxy's up for sale. $12,000 firm including all parts I still have, including both sets of wheels. Message me for details.
Old Aug 1, 2023 | 09:30 AM
  #132
DannyJ7's Avatar
Foxy is SOLD!
Old Jan 31, 2024 | 12:10 AM
  #133
be12nard's Avatar
Finally got around to putting the skirt kit on...The one I bought 4 years ago... LMAO.
where did you purchase this kit? Are they from the sport model? Thanks!
TFB Designs
Dec 1, 2012 12:08 PM
towelie
Jun 20, 2009 01:01 AM
awptickes
Jun 12, 2009 11:12 AM
Slimjimx701x
Feb 21, 2009 07:59 PM
hmgFIT
Nov 14, 2008 03:20 PM
