TPMS light
Old Feb 24, 2015 | 10:38 AM
Ron Belisle's Avatar
TPMS light
The tire shop just took off my snow tires (with no TPMS) and put back on my factor tires and wheels. After 3 days the TPMS light indicator on the dashboard is still on. The tire shop guys said it will go off in a day or two, but not yet. Will it?
Old Feb 24, 2015 | 10:49 AM
exl500's Avatar
Check your manual. There is a reset button below the wheel at the bottom of the dash. My dealership accidentally left it on after refilling my tires.
Old Feb 24, 2015 | 11:11 AM
GeorgeL's Avatar
And, your wheels have no TPMS sensors at all. The wheel speed sensors are used to trigger the light. Put your pressures where you want, reset the system, and you'll be good.
Old Feb 24, 2015 | 02:00 PM
GoBucky's Avatar
My TPMS light came on the day after I got it, I reset it and haven't seen it again.
Old Feb 24, 2015 | 03:01 PM
2007Fit5AT's Avatar
Snowy winter already over in your area???
For us "easterners" still at least one more month to go, usually first week of April I get rid of the snowy tires and put back on my 205/40/R17 aftermarket Enkei rims and tires until next Dec.
Drive safely out there.
Chris
Old Feb 24, 2015 | 08:37 PM
DArkk's Avatar
I had to reset mine a couple of times. I made sure the tires had the proper pressure.
Dunno. I guess it tends to be flaky at times.
Old Feb 24, 2015 | 08:52 PM
ThrillHouse619's Avatar
Once you reset you should be good, I was worried for a bit first too.
Old Feb 24, 2015 | 09:49 PM
bach's Avatar
Originally Posted by 2007Fit5AT
For us "easterners" still at least one more month to go, usually first week of April I get rid of the snowy tires ...
The way things are going this winter, you might have to push that date back a bit ...
Old Feb 25, 2015 | 08:03 AM
GoBucky's Avatar
Yeah, we're not getting the snow that you east coasties are getting pounded with, but I can't wait til these cold temps go back to Siberia.
Old Feb 26, 2015 | 04:06 PM
Kdawgz's Avatar
Inflate the tire to your optimal desires, install these Victor Aluminum Sport Valve Caps 22-5-07260-8A: Advance Auto Parts
It's safe, it don't get seized like those ebay ones since the inside is plastic ( I learnt my lesson)
Once you inflate the tire hold the tpms button for 5-10seconds and it will go away.
Old Mar 22, 2015 | 07:58 PM
Uncle Gary's Avatar
Proper procedure is this (from the manual): With the transmission in P or N (manual trans.) turn on the ignition without starting the engine (pos. 2). Press and hold the TPMS button until the TPMS light blinks twice, then start the car and drive it. The system will recalibrate itself while you drive.
kevinrbellamy
Aug 23, 2016 04:59 PM
bargainguy
Dec 5, 2014 10:05 PM
rodney
Oct 4, 2014 01:13 PM
Bustov
Feb 25, 2009 01:40 PM
jetscream
Jul 25, 2008 12:16 AM
